HELP ! URGENT PLZ
Word :   Username :
Bottom
Author
 Thread : HELP ! URGENT PLZ
Profile: stranger
More Information
well i have decided on my final build plz evaluate it
nd have few doubts too..
1.Intel Q6600 processor
2.Mobo- Asus P5E X38 / intel 975
3.2 gb crucial ballistix ram
4.500gb seagate sata 2 hdd
5.22" dell screen
6.Psu antec 650w
7.Themalright ulta 120 xterme heat sink
8.Antec 900 case
how is the overall build ??
also is 650w psu sufficent ?
and lastly if asus p5e x38 is not available which is the substitute for it ?
in the same price range nd good for OC'ing ..since m gonna oc it
thanx.
Related Product
Profile: enthusiast
More Information
i think you need a grafics card for that 22inch screen
Profile: Ancient Poster
More Information
You can go with 500W for the PSU depending on the graphics card.
I would go for a Corsair HX-520 or choose from below:
Top Tier PSU:
http://www.tomswiki.com/page/Tiere [...] ngs?t=anon
http://www.xtremesystems.org/forum [...] p?t=108088
http://www.jonnyguru.com/forums/showthread.php?t=1460
Silent PSUs
http://www.silentpcreview.com/article699-page1.html
AMD Certified PSUs (Single+Crossfire):
http://ati.amd.com/online/certifiedpsu/index.html
Certified SLI-Ready Power Supplies
http://www.slizone.com/object/slizone_build_psu.html
X38 is a chipset and 975 another older chipset. You are looking at X38, not Intel 975 with that motherboard. Maybe you meant LGA 775, which is the socket.
Message edited by evongugg on 06-16-2008 at 04:52:28 PM
Scruze my English!
Lord of the Duck Clan
Profile: Faithful Poster
More Information
1. Good plan
2. That is motherboard I have- great board but you don't need a $220+ motherboard. Look at the P45 boards instead. Asus P5Q Pro (Crossfire board) or MSI P45 Neo-F (non X-fire but only $99)
3. This RAM has had issues. I would go with G.Skill kits instead.
4. Good
5. Brand?
6. PC Power and Cooling 610W instead
7. You can do better here
8. Ok
Overall- Fair, you can do better with suggestions above
Change the PSU to what I said, Antec PSUs are just OK
Read above on motherboard
P45/X38 will OC great. I got my Q6600 to 3.6 easily.
Like vochtige said though, it might be hard to plug in that monitor without a video card.
http://www.tomshardware.com/forum/ [...] ate-modode <-- Computer Builds
Success comes from knowing that you did your best to become the best that you are capable of becoming."-John Wooden
More Information
The Xigmatek is rated No. 2 at the moment. Your choice is not bad though.
Top 5 heatsinks:
http://www.frostytech.com/top5heatsinks.cfm
Scruze my English!
Profile: enthusiast
More Information
If you are gaming you need a graphics card. For just general use (ie word processing, XP, etc) you can get away without one.
If you are gaming go with Vista 64bit and 4gb of RAM.
Profile: member
More Information
try the 4870 when it comes out.
Google Ads
News
Polysilicon Spot Price Posts Mild Drop
Published on July 22, 2008
Despite the spot price of polysilicon still remaining high, a mild weakening sign has been seen over the recent month. Read more
GPS can help give early warning of tsunamis
Published on June 30, 2006
Using GPS (global positioning system) data to measure how points on land move following an undersea earthquake could help geologists decide if the tremor will cause an ocean-wide tsunami. Read more
MIT researchers developing a quarter-sized turbine engine
Published on September 20, 2006
MIT researchers have started putting entire gas-turbine engines on tiny silicon chips. With the help of some military funding, researchers have fashioned millimeter-sized compressors, combustion chambers and turbines and placed them on layers of silicon wafers. Read more
PhD Student Makes World's "Most Advanced" Walking Robot
Published on May 23, 2008
Delft (Netherlands) - A PhD student at the Delft University of Technology in the Netherlands has constructed what he says is the world's most advanced walking biped robot. Read more
Latest Reviews & Articles
Best Video Cards For The Money: Oct '08
Published on October 06, 2008
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. At the end of the day, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
Atom, Athlon, or Nano? Energy-Savers Compared
Published on October 03, 2008
We compared Intel’s Atom 230 and VIA’s Nano L2100 processors hoping to find the best product for low-power applications. VIA is in the vanguard of performance. Is this enough to beat Atom? Read more
Interview: Bigfoot's Killer NIC, Exposed
Published on October 02, 2008
Since its release, the Killer NIC has garnered a reputation for being an extravagant and largely unnecessary add-on for the do-it-yourselfer. Seeking additional insight, we approached the card's designer. Read more
Seagate's 1.5TB Barracuda: Bigger And Better?
Seagate is the first hard drive vendor to offer a 1.5 TB drive in the 3.5” form factor. Meanwhile, WD sent us its RAID Edition 3 (RE3) drive. We tell you which is the best HDD choice today. Read more
