I have an nForce 780i motherboard and a Q9450 CPU. I built it last July or August I believe, all new parts. I had an Arctic Cooler 7 CPU heatsink and MX-2 thermal paste. I have 2 120mm fans, one in the front and one in the back of the tower, with a Thermaltake case and an Antec 850W PSU. Everything worked fine at school for a year. I usually keep the computer on at all times, overnight, for days and days. No problems up until moveout day.
I moved my computer and self home from school yesterday and built a new desk for my computer. Turned it on, and after a while, it shut off completely, no warning. I knew in the back of my mind it was overheating but didn't see how it was possible. I moved it into a spot with more airflow and let it play for a few hours, and then try to use it and it shuts off. I watched the BIOS and the cpu temp is ~100C before shut off.
I bought new thermal paste today, wiped clean the cpu and applied the new paste, reinstalled the heatsink and turned it on and went to BIOS, watched the cpu temp go from 85C - 115C (!!) before shutting itself off.
What is going on? I know the CPU heatsink is installed correctly (at least I have to imagine it is), the thermal paste is on. The only thing I can't think of is the rear 120mm fan is orange and I don't see it moving on turn on, but all is plugged in.
Any advice/other things to look at/what to do?
