If that is a top quality 400W power supply (which i don't think it is) then the computer would probably be fine. If it is one of those cheap $10-$15 400W power supplies then I think that PC will crash and burn very quickly.
EDIT: If you are looking for a new PC, build it yourself. You can build that exact same PC for probably a few hundred dollars cheaper and even throw in a better video card. If you are definitely not going to build, i suppose you could get that and maybe upgrade the power supply.
Message edited by helios2052 on 08-04-2008 at 07:08:56 PM
If you don't want to build go ahead and buy it. Hopefully gateway uses standard power connectors so that the psu can be changed if it gives you problems.
