Tom's Hardware > Forum > Homebuilt Systems > New System Build > New Computer Build – Monitor problem
Forum Homebuilt Systems : New System Build - New Computer Build – Monitor problem
Hello everyone,
I’ve been having a big problem with my new computer build, and I’m hoping someone may have some ideas. Here are my specs:
ASUS P5E3 Deluxe/WiFi-AP LGA 775 Intel X38 ATX Intel Motherboard
BFG Tech BFGE981024GX2E GeForce 9800 GX2 1GB (512MB per GPU) 512-bit (256-bit per GPU) GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
Western Digital Raptor X WD1500AHFD 150GB 10000 RPM SATA 1.5Gb/s Hard Drive (2)
Intel Core 2 Duo E6850 Conroe 3.0GHz LGA 775 65W Dual-Core Processor Model BX80557E6850
PC Power & Cooling T12W 1200W ATX12V / EPS12V Power Supply
CORSAIR TWIN3X2048-1600C7DHX2GB PC3-12800+ (DDR3 1600+) DDR3 Memory
Here is the problem. I put the system together, and it powered on fine, but when the monitor was connected to the video card, nothing happened. The monitor wouldn’t work at all.
I’ve tried the new video card in my older system, and it works fine so I know it’s not the card. I assumed the motherboard had a bad socket, so I RMA’d it, and received the replacement, but it’s doing the same thing.
I also tried my old 7800 video card in the new system, and it also didn’t power up the monitor.
I suspected maybe a problem with the RAM, but it seems this particular motherboard only supports DDR3, so I can’t use any of my other RAM to test it.
I am using the same monitor for both systems. It works fine with the new video card in the old system, but it does not work at all with the old or new video cards in the new system. I also tried another monitor that I had stashed around, and it also didn’t work.
Has anyone ever had a problem like this? I suspect also a BIOS problem, but I can’t really access that without the monitor.
Thanks in advance for any help!
Message edited by chi83 on 06-17-2008 at 06:51:08 PM
Sponsored Links
Clear the bios by removing the battery for 30 secs.
Might be a short somewhere. A cable connected wrongly. An extra standoff.
Take the motherboard out and put it on a piece of cardboard with only processor and power. Listen for beeps and then try adding in memory, then video card, etc.
Try using one stick of RAM instead of 2.
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
Do you have a case speaker attached? That will give you any beep codes to decipher the problem. If not, you can pick up one up at your local store.
You've eliminated a few items, which is good: motherboard, monitor, graphics card. Time to look at the common elements:
Power supply (could be DoA; can you try out a different one?), CPU (bent pin?), RAM (try each module separately). Or your motherboard could have a short somewhere on the case (try building outside the case). Also ensure that you have the CPU power cable (4 pin) connected snuggly to the motherboard. Also try clearing the BIOS either by removing the battery or using the BIOS reset jumper.
Message quoted 1 times
Message edited by qwertycopter on 06-17-2008 at 06:32:08 PM
Reply to qwertycopter
If you need a speaker, you can get one here:
http://www.pc-extras.com/prods/bsspm1.html
Site experiencing difficulties at the moment
Reply to evongugg
So how big is your monitor? :kaola:
edit: added smileys for clarity
Message edited by sciggy on 06-17-2008 at 06:54:17 PM
------------------------------ http://valid.x86-secret.com/cache/banner/377091.png
NZXT Apollo PCP&C Silencer 610 watt
VisionTek 4870x2
Seagate 7200.10 500gb
Reply to sciggy
I think he meant the monitor problem was big, not the monitor :)
Reply to aevm
She, and yes, that's what I meant. :)
Probably should have been a bit clearer but I'm getting rather frustrated at this point and not completely coherent.
Thanks all for the advice so far, I will try your suggestions.
Reply to chi83
I guess I should have been more clear that I was joking, perhaps adding a few smiley faces?
VisionTek 4870x2
Reply to sciggy
I vote you didn't plug in the 4/8 pin 12v cpu power connector.
Reply to roadrunner197069
Heh, sorry. :P
I try not to assume things so I tend towards literal interpretations, though that occasionally backfires.
I should have realized it was a bit ambiguous of a subject anyway. I've edited the topic!
Reply to chi83
Did you double check the 4/8 pin connector?
Looks like you have the 8 pin see here bottom left 8 pin cpu power connector:
http://www.newegg.com/Product/Show [...] otherboard
Unfortunately, yes, it's been double checked.
I will triple check it though, as a lot of people have suggested that.
Thanks!
Reply to chi83
The next thing is a short or incompatible ram. Did you use standoffs? Did you use the right amount? Is the Ram on the Mobo QVL list? ALso I just noticed your memory is 1600 and your mobo only supports 1600 (OC) which your ram default is 1600 so the settings are wrong. You need to get 800/1066/1333 ram to boot with and change bios settings to use your other ram. I would get the 800 if it was me. Just 1 stick, it dnt even need to be 1G, get the cheapest you can.
Hmm, forgive my lack of highly technical knowledge, but is the 1600 per module? So basically I couldn't accomplish the boot only using one of the pair?
ETA: I have tried it only using one and it hasn't worked.
Message edited by chi83 on 06-17-2008 at 07:37:50 PM
Reply to chi83
Exactyl 1600, wont boot without being set in bios first.
That's a good start on hardware troubleshooting.
Clear the BIOS. Then try this:
http://www.tomswiki.com/page/Troub [...] +New+Build
------------------------------ Overclocking since 1978: TRS-80, 1.77 MHz Z80 to 2.01 MHz.
Reply to jsc
There are 1253 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
