Power Connectors for p5q deluxe
  • Motherboards
  • Power
  • Product
August 29, 2008 1:54:06 PM
Hi,
I have plugged the 24 pin power connector onto the motherboard.
There is a 4 pin connector at the top of the motherboard but I cant get the 4 pin cable to reach to the top.
Do I need this 4 pin connector plugged in?
Ta
More about : power connectors p5q deluxe
a c 242 V Motherboard
August 29, 2008 2:33:14 PM
Yes because it provides power to the CPU. You'll have to buy an extension cable.
August 29, 2008 2:38:58 PM
Any ideas what this extension would be called?
August 29, 2008 3:21:23 PM
Thank I found one at maplin eventually
August 29, 2008 9:18:31 PM
Yes.
