Tom's Hardware > Forum > Motherboards & Memory > Memory > Speed vs Quantity?
Ram Speed or Quantity more important?
Warning, if you click on "see results", you won't be able to vote
1.DDR2 or DDR3?
2.Speed or Quantity?
3.Does rams that have a speed over 800mhz generate heat a lot which causes system failiure?
Sponsored Links
I need urgent help from an expert about this issue, any help/reply would be appreciated
Reply to AlpEinsteiN
well for starters some idea as t what you plan to do with the machine?
overclocking? mild/medium/hardcore
what motherboard?
what CPU?
Power supply?
what OS do you plan to run? and what do you plan to do with it... gaming? CAD? Video processing? or just surfing the web?
before any advice can be given... no expert will give any without enough information...
------------------------------ Invented a new file compression... remove all the '0'. They are nothing anyways...
Q6600 O/C to 3.6Ghz wc
http://valid.x86-secret.com/show_oc.php?id=229261
Reply to MadHacker
Overclocking: Not planning to do it for now but will probably do hardcore clocking 6 mo later
mobo:haven't decided yet
cpu: bought a q9450
power supp:750w
os: vista x64 I will do video editing-converting, 3d modelling, and will play upcoming games
graphics card: ATI HD 4870 X2
myself I do a lot of code development, video processing, Virtual Machines as well.
Using 4 gig of ram in Vista64 is enough at the moment (all apps i use are 32 bit) 2x2GB sticks.
I went DDR3 for future proofing. Nehalem systems will use DDR3 and I will go there eventually...
the latency that DDR3 has isn't that important then the lower latency DDR2 with your CPU...
as for Mobo, any thought weather to have crossfire support? if not then X38, X48 isn't that necessary...
P45 or P35
but best to figure out what all you want to plug into it and buy the board accordingly...
any other question....
ask away....
edit: BTW speed and quality go hand in hand. faster you go the better quality components you would want...
Message edited by MadHacker on 08-29-2008 at 08:26:22 PM
Reply to MadHacker
Simple answer: quantity.
Speed basically gave no noticeable performance increase, only boost synthetic benchmark scores.
If you run out of ram and starts to use a lot of page file of hdd, you'll definitely notice the PC speed tank.
------------------------------ Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Reply to dagger
There are 672 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
