I recently have been looking to build a new system, and came across a very good deal on a PSU, and with nVIDIA releasing a better, less expensive version of the 9800 gtx, it made me want it even more. So, I was wondering if the power supply I'm about to link will have enough power on the 12V rails to power the card and have room for possible expansion.
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817341002
GFX card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130376
P.S Thanks in advance for the reply, also it would be helpful if you could enlighten me on how you determined whether the PSU was suitable for the Card. Thanks.
