Hi,
I've just built me a new system: Rampage Formula and a QX9770. The system works fine and I wanted to overclock it a little bit, so I set the multiplier from 8.0 to 9.0 and Prime 95 ran for 10h without a single error. But when I switch my PC completely off (I switch the PSU off) and bott again I get the followin error:
"Error! The CPU to Bus ratio or VID configuration has failed"
I can then change the BIOS settings via F1 or load defaults with F2. If I choose F1 and change nothing the system boots properly and runs perfectly.
And the strange thing is: If i shutdown my PC and don't switch off my PSU this error does not occur. When I restart Vista the error does not occur, too.
That's really strange, isn't it?
I use BIOS version 403 (up to date) and have no idea what I can do to solve this problem. Any ideas?
Thanks in advance
capsad
Thanks in advance
capsad
