Archived from groups: microsoft.public.windowsxp.basics (More info?)
I have windows XP home SP2. After 2 years my CD writer has stopped reading
or burning discs. The light keeps flashing and "My Computer" file stops
responding at the same time.
My event viewer shows; "event ID 9, source atapi. The
device,\Device\Ide\IdePort1, did not respond within the timeout period".
My help and support centre tells me; "If there is a disc in the CD-Rom drive
it might need replacing or cleaning". This problem occurs with any disc
including blank ones and also at times without a disc at all.
Could anyone please tell me how to rectify this problem.
Sponsored Links
> reading
> stops responding at the same time.
> period". My help and support centre tells me; "If there is a disc in
> the CD-Rom drive
> disc including blank ones and also at times without a disc at all.
Yes, it's time to replace the drive. You might want to replace it with a
DVD R/W if you don't mind spending a little more. Otherwise, you can
get a CD-RW drive for $25-40 USD. I like www.newegg.com and they have
some really good deals. Of course, it depends on what country you live
in.
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
Reply to Malke
Might try also a CD lens cleaner disk, but I'd say there's a pretty fair
chance that the drive is toast.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
"Killian" <killian@abcz.com> wrote in message
news:u6QAdKTpFHA.3004@TK2MSFTNGP15.phx.gbl...
> drive it might need replacing or cleaning". This problem occurs with
> any disc including blank ones and also at times without a disc at all.
Reply to Anonymous
Thanks people, I had already tried a cleaner disk without result. I'll
remove the unit because it's a nuisance as it is and have it for breakfast.
I'll replace it later with a DVD recorder.
"Rick "Nutcase" Rogers" <rick@mvps.org> wrote in message
news:%23kGaiBXpFHA.4056@TK2MSFTNGP10.phx.gbl...
> Best of Luck,
>>reading or burning discs. The light keeps flashing and "My Computer" file
Reply to Anonymous
- 0 +
I am also having a problem with my cd drive. It just doesn't read the cds.
It works with dvds. Will open and play them ... In the cd drive nothing.
Any ideas.
thanks
> Best of Luck,
Reply to Ruby
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > CD writer problem
There are 1156 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
