Tom's Hardware > Forum > Overclocking > CPUs > Q6600 OVERCLOCKING HELP
Forum Overclocking : CPUs - Q6600 OVERCLOCKING HELP
THE RIG
CASE: NZXT TEMPEST
PSU: CORSAIR HX-1000
CPU: INTEL Q6600 GO 2.4ghz
GPU: EVGA GTX 285 x2 SLI (Overclocked to the gtx 285 ssc edition)
MB: EVGA 750i SLI FTW
RAM: CORSAIR XMS2 8gb 800mhz
HS: MASSCOOL 8WA741
HDD: SEAGATE 500gb
OS: Windows VISTA ULTIMATE x64
CPU Temps: 35 idle / 45 load
GPU Temps: 40 idle / 50 load
THE PROBLEM
I have never overclocked before and want to get my q6600 go to 3.2ghz
BIOS Says v-core is 1.35 and CPU-Z says 1.28 ( It is a GO ) where should I start?
Sponsored Links
Read, read and read some more. I have just OC'ed my Q6600 to 3.4Ghz or thereabouts and I began with the Tom's guide written by Graysky. It takes patience and time but it is SO worth it when you see your CPU running at uber speeds (well that's how I feel!)
Also, I think overclocking has high addiction potential......good luck.
AC
Reply to ac3144
Quote :
With a lot of reading? If you don't understand what your doing, you can cause a lot of damage to your stuff. People can tell you to do things, but if you don't understand, or move the wrong setting, ZAP.
For newbies to overclocking, I usually suggest DON'T change any voltages. Not until you know how things work. The Q6600 is 266x9 = 2.4GHz. If you want 3.2GHz, thats 3200 / 9 = 355MHz. I'd actually set the FSB to 400MHz, that way your DDR2-800 ram is actually running at 800MHz. (You did set the FSB:RAM ratio to 1:1 right?) If you then drop the multiplier down to 8, 400MHz x 8 = 3.2GHz. No clue how doable this is without a voltage bump, having a G0 will help. If none of this made ANY sense, DON'T try overclocking.
------------------------------ The voice of REASON
Do NOT feed the TROLLS!
Always a DEMON!
Reply to 4745454b
- 0 +
There's two stickies you need to read:
http://www.tomshardware.com/forum/ [...] uals-guide
http://www.tomshardware.com/forum/ [...] ture-guide
Then you need to find a guide for your specific motherboard.
The second guide is technically pretty difficult. But you need to have a pretty good idea about max voltages, temperatures and thermal management.
Message edited by jsc on 05-29-2009 at 02:01:28 AM
Reply to jsc
There are 1218 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
