Tom's Hardware > Forum > CPU & Components > CPUs > What is the average CPU power?
Forum CPU & Components : CPUs - What is the average CPU power?
I am creating a flash video and don't want to incapacitate anyone's computer by setting the frame rate too high. But i want the video to be as smooth as possible.
Does anyone know of a site that could give me an idea of what kind of CPU the average American consumer has in their PC?
Even if its in flops or something like that. that would probably be the easiest to compare to.
example: Average CPU runs at 30MFlops, test flash video on a 60MFlop CPU. see what the usage is. double it. and i'll have a good idea of how to adjust the fps accordingly.
Sponsored Links
try the steam survey, made not the average person but a good amount people who use broadband.
------------------------------ I'm a git, deal with it.
Antec 1200,PC Power & Cooling 750,Gigabyte DS4-x48,Intel Q9550@3.4 W/Xigmatek S1283,8GB OCZ DDR2 800,ATI 4870X2,X-FI>CA 640C amp>Tannoy R300/Senn 595's
Reply to strangestranger
most advanced users have a high AMD based system or a core 2 system... average though is probably pentium d's/ and amd 3000 - 4000 X2's... but those people probably won't be watching or using the flash... so i'd say a low end core 2 system is what you want
Reply to thogrom
i had thought about the steam survey, i myself have submitted my system on there, but the problem is, it only tells me what the speed of the cpu is. and we all know a core 2 duo at 2.00ghz is way faster than a pentium 4 @ 2ghz.
ill keep looking, but if anyone find something a little more accurate in terms of raw processing power and not ghz, let me know.
Reply to nowwhatnapster
It's not really a question of the cpu. And it should not be a question of your framerate which should be on the order of 30 fps (or more specifically, 29.97 fps). 24 fps is typically used for film and some internet video.
It's more a question of your bitrate and compression, and the file format. A flash file can be progressively played over the internet or downloaded in its entirety and converted to any number of formats.
With a progressive download the file may be buffered and streamed at an acceptable level for your client to maintain a decent viewing. The higher the bitrate the better the quality but most folks will not hang around and wait if your bitrate is too high and the buffering too slow.
The maximum bitrate YouTube encodes Flash FLV files is 260Kbps at a resolution of 320 x 240. They then increase the resolution of the video to 425×350 which degrades the overall quality.
You need to provide a little more information as to your plans and how you plan to distribute the video.
Reply to wisecracker
There are 1136 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
