Tom's Hardware > Forum > Overclocking > Motherboards > How do I monitor my SB temps
Forum Overclocking : Motherboards - How do I monitor my SB temps
If in the future I was to buy a better CPU cooler, what software can I use to monitor my Asus Maximus Formula's SB. I know I can use the Asus software but a few people have told me to keep away from it as it causes problems. I know that my SB has ran hot in the past so I really need to keep an eye on it.
Also what cooler would you guys recommend for a Q9450 in an Antec Twelve Hundred case? I've only bought one CPU fan in my life so have no idea whats the idea price to spend on these.
Thanks for anyone who can help.
Sponsored Links
The only program I know of is Everest. Its a paid app, if you don't have it just download the beta or trial so you can check your temps. See the Northbridge (SPP) and Southbridge (MCP) temps.
Reply to starams5
Well you can get an alright cooler for $20-30 ish... The Xigmatek HDT-S1283 is a very good cooler for around that price, and if you are willing to spend lots of money, you can get a Coolermaster v8 or v10, both being quite new to the market.
Message edited by computabug on 05-30-2009 at 04:03:34 AM
Reply to computabug
Asus Probe II is actually not bad. Also how much do you want to spend on the cooler?
Reply to Ragsters
Do your ASUS Probe show your NB & SB? Mine don't, the last time I seen the NB & SB temps were when I had my 650i. I even tried older versions, no go. I currently have a 750i & 780i and neither show the NB & SB temps. If know something I don't please share those features are missed.
Reply to starams5
Taking the motherboard out would be a right pain. Do the better heatsink fans require you to do this? (I would guess so with the size of them). Are there any that are good and don't require you to do this. I'll spend around £30 on one. Unless a few pounds more provides alot more cooling.
Reply to Dark Comet
Most of the top notch air cooler's require taking the board out for the bracket. If you don't want to take the board out take a look at the Arctic Cooling Freezer 7 Pro:
http://www.newegg.com/Product/Prod [...] 6835186134
Reply to starams5
Ok cheers I'll look into that. I'll need a really good fan to Overclock because after 3 minutes of prime 95 I'm getting 76,71,74,74C on real temp 2.5 (TJ max 95) and thats stock speed :(
Message edited by Dark Comet on 05-30-2009 at 08:32:04 PM
Reply to Dark Comet
Cheers, that heatsink fan seems to get good reviews from people and is only £15 in the UK so thats half of what I was going to spend.
Reply to Dark Comet
My motherboard is an Intel so maybe the AMD ones don't have that option for some reason. So if there is no free option I guess I'll have to use the Asus software. Have you guys had any problems with it in the past?
Message edited by Dark Comet on 05-30-2009 at 09:05:15 PM
Reply to Dark Comet
I'm running Intel as well an E6850 and E8500. Maybe it varies from board to board I don't know, but it cool to open the probe and see those features while setting up your OC, thanks.
Reply to starams5
Sorry, I was referring to the chipset. My bad, Nvidia not AMD.
Message quoted 1 times
Message edited by Dark Comet on 05-30-2009 at 09:23:02 PM
Reply to Dark Comet
A buddy I thought of that to, my last 3 chipsets have been nVidia and as I stated above it worked on my older nVidia chipset 650i. But I was thinking maybe it has something to do with the 7xx chipset because I can't use the HDD SMART feature either. I looked into it although I don't remember the details but the nVidia chipset limits monitoring certain motherboard features. I put the question to the guys at the ASUS forum as well and got nothing, you were my last hope...... :cry:
Reply to starams5
Ah sorry not much I can say there. Have you emailed ASUS? It would be strange if the guys at ASUS didn't know why their software does not fully work with their motherboard. I don't see why they would limit that :(
Reply to Dark Comet
"you were my last hope......" I was just joking with you. I just did like I always do adapt to the situation and move on. Kind of like going from an old OS to a new one and finding your favorite software don't work anymore. Thanks and take care.
Reply to starams5
I use a Artic Cooling Freezer Pro 7 and my Q9450 @3.3GHZ runs at 57 C after 24 hours of Prime 95. It runs at 58 C after 2 hours of OCCT with Linpack
Reply to pajama
Great, do you remember what your stock cooling was like? I heard that the Q9XXX fans were worse then the Q6XXX so maybe a fan upgrade will sort me out.
Yeah thanks for the help. Do you just ignore your SB temps now?
Message edited by Dark Comet on 05-31-2009 at 05:22:34 PM
Reply to Dark Comet
See my 1st post at the top. I wish I could ignore it, I run my NB & SB at 1.60v for a stable OC.
Reply to starams5
There are 1259 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
