Tom's Hardware > Forum > Storage > Hard Disks > Hard drive showing 23gb on 250gb hard drive
Forum Storage : Hard Disks - Hard drive showing 23gb on 250gb hard drive
Windows xp
hp a1130n medica center pc
wd2500jd hard drive
Bios recognizes it as 250gb. But when I click under computer, my c drive is listed as 13gb and my recovery d drive as 6gb. I've run the SMART test in bios, disc error checking, and the quick test iso from the western digital web site, and every test says the hard drive is ok.
BTW this is after doing a system recovery from the hp disc's that didn't go so well. It was running bout 20hrs and alt-tab-deleted to task manager and ended everything. But everything seemed to be ok and runs fine..I was able to register product...etc.
The only problem's the hard drive showing up so small.
Should I reformat c drive and start the long recovery again? The problem is when i go to format it's saying the size is only 13gb. I wanna format 250gb.
What should I do??? Please help!
------------------------------ Q6600 at 3.2ghz,680i sli,
vista 32-bit,
4gb corsair 4-4-4-12 ddr2, 8800gt 512mb w/ zalman vf-900, zalman 9700, theramltake armor, 2-250gb raid 0,
Sponsored Links
I'm not really sure, but I think you only have 13GB left because there are already applications and data on your hard disk. This is a relatively old computer were talking about, right?
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Reply to r_manic
Yes, it's an older computer w/ a socket 939. However, when u rt click on the c drive and click properties it should still show the drive's capacity...which is not 13gb....it should be close to 250gb. Never did the recovery correctly and this is probably why I get the low volume.
Fix: I fixed by formating the d drive (recovery partition). c drive wouldn't let me format it.
Then, I restarted pc w/ recovery cd, did the format process and everything's fine now. c drive shows close to 250gb.
vista 32-bit,
Reply to Raydog
There are 789 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 raulkm won the Uniformed badge
  • 01:00 letus won the Uniformed badge
  • 01:00 pmiddy won the Uniformed badge
  • 01:00 MarcieMark won the Uniformed badge
  • 01:00 kaypeezee won the Uniformed badge
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
  • 01:32 aford10 won the Home Brew badge
  • 01:00 Kevinator won the Uniformed badge
  • 01:00 adis won the Uniformed badge
