Tom's Hardware > Forum > Homebuilt Systems > New System Build > $1500-2000 Gaming system w/ 9450 Yorkfield - Finalizing - Need advice!
Forum Homebuilt Systems : New System Build - $1500-2000 Gaming system w/ 9450 Yorkfield - Finalizing - Need advice!
I'm building my first PC. I want it for HTPC and Gaming. I want to play WoW and Crysis. I will be hooking it up to my 46" 1080p hdtv. So I want to be able to get the most out of my hd files to play on the tv and get the most out of WoW and be able to play Crysis.
I have gone back and forth several times on several motherboards and am at a total loss at this point so that is the thing I need the most advice on. Though I'd like advice on anything else.
CPU: Intel Core 2 Quad Q9450 Yorkfield 2.66GHz
Motherboard: Please help!
Video Card: EVGA GeForce 9800 GX2 basic version non ssc
RAM: OCZ Gold Edition 2GB (2 x 1GB) 240-Pin DDR3 SDRAM DDR3 1333 (4gb total)
Case: NZXT LEXA Blackline Series ATX Mid Tower Computer Case (will the components fit it)
Power Supply: OCZ GameXStream OCZ700GXSSLI 700W ATX12V Power Supply 100 - 240 V
I don't plan to overclock anything until I need to(which would probably be for future games). So I will overclock it in the future. At present I don't plan on getting a second video card but may in the future. I also like the idea of the two gigabit lan ports doubling the bandwidth with the 790i board, but don't know if its worth it to spend all that money.
Any advice is appreciated.
Also, would a sound card be necessary, or do modern boards cover that well?
Sponsored Links
Ditch the 9800 GX2. That card is a very bad value. It is two underclocked 8800GTs that cost more than a 8800GT SLI setup does.
790i is VASTLY overpriced and loaded with problems. Avoid.
Ditch DDR3, overpriced and does not offer performance to justify the cost.
The best video cards for HDTV is actually ATI because of their native HDPC and HDMI support.
I would look at the following setup:
Q9450
Asus P5E x38 Motherboard
Video Card: ATI 4850 x2 in Crossfire
RAM: 4GB G.Skill 4-4-4-12
Case: Ok
Power Supply: PC Power and Cooling Quad 750W.
Sound Card: Not required.
------------------------------ http://www.tomshardware.com/forum/ [...] ate-modode <-- Computer Builds
Success comes from knowing that you did your best to become the best that you are capable of becoming."-John Wooden
Reply to shadowduck
I just built my first PC, and I went with the EVGA 780i mobo. I had absolutely no issues, and their tech support is really helpful. DO NOT go for the 790i, they are still having tons of problems, and the price of ddr3 is totally no worth it, as far as performance. Go with a ddr2 mobo, and my advice is the 780i from evga, but I am sure others on here will say they recommend something else that's better. Again only my opinion, and my good experience with it. Not too sure I would go with that video card though, I am running 2 evga 8800gt's in sli, and am very satisfied with the performance, plus they are getting cheaper by the day. Or, nvidia just came out with the new gtx 200 series card, check them out, but they are also very expensive. Good luck, we'll be here. Oh and take your time, and read your manuals, I did and had no issues.
Reply to bryan240g
Also what type of pc input does your tv have? hopefully at least dvi, or better yet an hdmi input.
Reply to bryan240g
Thanks for your quick response!
What about the ATI card for playing Crysis, will it work? I'm not a crazy gamer that has to have it all perfect but I want it to look good and play smoothly.
The other thing, is it very noisy with two video cards? I'd like to have a fairly quiet pc.
Reply to 21may2008
Yes 4850 handles Crysis BETTER than 8800GT.
What is noisy to you is relative to your sensitivity. I cannot hear my video card (3870) over softly playing music. When everything is off, its a hum that is not distracting to me in anyway.
Reply to shadowduck
my tv has hdmi inputs which was one of the reason s I liked the 9800gx2
Reply to 21may2008
The noise will depend on your case. I have 4 120mm scythe fans going, and mine is pretty quiet. Yes I see no reason that the ati cards would not work, they should work just fine.
Reply to bryan240g
Whats the difference between the 3870 and 4850?
Reply to 21may2008
Not sure go to newegg.com and compare the 2. From what I just saw, the price, and the fact that the 4850 has alot more stream processing units.
Message edited by bryan240g on 06-20-2008 at 05:13:13 AM
Reply to bryan240g
3870 is the older generation ATI card. It the one I have and it is a fine performer.
The 4850 just came out based on a completely new core. This video card beats the 3870 easily, and holds its own. In some tests it even torches 9800GTX.
In Bioshock for example, 4850 beats every other video card tested except 9800GX2. This INCLUDES 260.
Quote: "AMD's new 4850 just destroys its competition and just about everything else in this test. Not even the new GTX 260 which costs twice as much can touch this card in Bioshock. Performance here is simply incredible."
Message edited by shadowduck on 06-20-2008 at 05:15:09 AM
Reply to shadowduck
great, thanks. And do you think I should get the pair of the 4850's to doe the best for my expressed needs?
Reply to 21may2008
Since you are running 1920x1200 resolution- yes you are a candidate to Crossfire them. Get 2.
Reply to shadowduck
Can anyone tell me if Tiger Direct is safe to buy from these days. They have a combo deal of the Intel xt38 and 2gb of ram for the same price that New Egg offers the board by itself. It seems too good to pass up, but i've read some things that Tiger Direct isn't that good to buy from.
Reply to 21may2008
Even if you aren't going to overclock plan on getting an aftermarket HS of some sort...or at least check the clearance around your CPU bracket. I got my stuff in last night and the stock Q9450 HS wouldn't fit on my board as the bracket legs weren't tall enough to clear the transistors sitting next to the CPU...there is very little clearance on the stock HS.
You may not have that issue on your board but wanted to throw that out.
Reply to johnnymac13
not entirely sure about Tiger Direct, but newegg.com is always spot on with service, and even prices for the most part.
Reply to madaniel
If you want ALOT more performance, wait a couple days for the 4870.
Reply to sogangsta
- 0 +
Awaiting the 4870x2's. 2x or 3x of those would be pretty sweet imho.
------------------------------ Intel Core 2 Quad q6600 @ 3.0ghz // 8GB PC8500 RAM @ 1066
2x WD Velociraptors 10k rpm RAID 0
3x (Tri-SLI) BFG NVidia GeForce 8800 GTX OC 768MB
3x 30" Dell 3007WFP Monitors
Reply to Oh Snap
any idea if the 4850 and 4870 are compatible together in crossfire? not sure if I want to afford two 4870s unless there are compatibility issues, or might it be best to wait for the 4850 dual gpu card that I seem to now see rumor of scheduled for 8 weeks from now
Reply to 21may2008
- 0 +
http://www.newegg.com/Product/Prod [...] 6819115042 $329.99
Intel Core 2 Quad Q9450 Yorkfield 2.66GHz 12MB L2 Cache LGA 775 95W Quad-Core Processor - Retail
http://www.newegg.com/Product/Prod [...] 6813128336 $224.99
GIGABYTE GA-X48-DS4 LGA 775 Intel X48 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Prod [...] 6820146731 $89.99 ($74.99 after $20.00 Mail-In Rebate)
mushkin 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Prod [...] 6814125224 $199.99
GIGABYTE GV-R485-512H-B Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Prod [...] 6817139006 $129.99 ($119.99 after $10.00 Mail-In Rebate)
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V Power Supply 100 - 240 V UL, CE, CB, TUV, FCC, CCC - Retail
http://www.newegg.com/Product/Prod [...] 0&Tpk=mx-2 $6.99
ARCTIC COOLING MX-2 Thermal Compound - Retail
Total
$1,181.93
$1,151.93 w/mail in rebates
------------------------------ "God invented Google so you would stop asking stupid questions."
Reply to Why_Me
quick question. Would this:
http://www.tigerdirect.com/applica [...] 62%20PROMO
be better having ddr3 ram(with those 2gb free and another 2gb for about $90. it would be the same price for me to get that as the board and ram you listed. However I don't know much about cas latency, though another thing that is a factor for this whole build is future proofing so that when I need faster ram and the price comes down, I can get it.
Long story short, is that ddr3 ram with high latency equal in speed to the ddr2 ram that you listed with lower latency?
Also, should I get a heat sink and fan for the cpu or is that thermal compound all that is needed. I've never used any cooling and this is the first system I've build so sorry for the newb questions but I do appreciate all the answers and advice from everyone.
Thanks
Message edited by 21may2008 on 06-22-2008 at 06:44:05 AM
Reply to 21may2008
If you want to overclock ever, do not buy an Intel board.
For DDR3 that is pretty low end memory.
You do better with what Why_Me suggested.
Reply to shadowduck
Hey guys, so I baulked at purchasing right away b/c of some of the reviews on the 4950 video cards saying that they ran very hot, and wanted to wait out the x2's.
would you guys recommend either one of the x2 cards for my needs?
"I'm building my first PC. I want it for HTPC and Gaming. I want to play WoW and Crysis http://en.wikipedia.org/wiki/Crysis . I will be hooking it up to my 46" 1080p http://en.wikipedia.org/wiki/1080p hdtv. So I want to be able to get the most out of my hd files to play on the tv and get the most out of WoW and be able to play Crysis."
Reply to 21may2008
I could also use some help/advice on cooling. i.e. case fan replacements, cpu, graphics card cooling.
I know nothing about the world of cooling and would greatly appreciate some advice in this dept
Reply to 21may2008
- 0 +
COOLING:
CPU
Xigmatek HDT-S1283 120 MM Rifle CPU Cooler
Xigmatek ACK-I7751 Retention Bracket
FANS
Xigamatek XSF-F1251 120 MM fan(s)
CASE
Consider the Coolermaster Cosmos S Case. Put 6 of the above 120 mm fans and keep side panel 240 mm fan
Great airflow in that set up.
Reply to Nytmare
thanks for the cooling advice, how are those on quietness? are they quieter than the sythe fans that bryan240g mentioned? he said that he has those and his pc runs very quiet.
also do I need thermal compound? I've no idea what the heck that is.
Reply to 21may2008
I may consider the antec 900 case: http://www.newegg.com/Product/Prod [...] 6811129021
what do you guys think?
The one you , nytmare , mentioned is a bit pricey for me
Also, is it possible to turn the blue lights off in the front, where the fans are?
Message edited by 21may2008 on 08-18-2008 at 08:55:54 PM
Reply to 21may2008
Looks like a nice build, pretty big budget to.
Reply to EGutierrez91
I noticed that the both motherboards you guys recommended (the x38 asus and the x 48 gigabyte) have different memory standards than the memory you recommended(which was less).
is this still compatible?
Reply to 21may2008
There are 932 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
