Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > (Almost) Finished Water Cooled Antec 900
Forum Overclocking : Cooler and Heatsinks - (Almost) Finished Water Cooled Antec 900
Well I finished my Antec 900 Project, I just need to mount the Rad properly.This is to show everyone who helped that they made a difference.[for anyone who helped me with the coolent I used distilled water and antifreeze wit orange dye]
http://i538.photobucket.com/albums [...] 1-2122.jpg
http://i538.photobucket.com/albums [...] 1-2230.jpg
http://i538.photobucket.com/albums [...] 1-2124.jpg
http://i538.photobucket.com/albums [...] 1-2126.jpg
Thanks To Everyone Who Helped
Message edited by xtream_ocer_intel_nvidia on 06-02-2009 at 12:06:36 AM
------------------------------ The Meaning Of Life
Sometimes it's a chicken,
Sometimes it's a chair,
Sometimes its a piece of cheese suspended in the air
Sponsored Links
Re posting pics as embedded
http://i538.photobucket.com/albums/ff346/rossyxyxyx/IMG00003-20090601-2122.jpg
http://i538.photobucket.com/albums/ff346/rossyxyxyx/IMG00017-20090601-2230.jpg
http://i538.photobucket.com/albums/ff346/rossyxyxyx/IMG00018-20090601-2230.jpg
http://i538.photobucket.com/albums/ff346/rossyxyxyx/IMG00005-20090601-2122.jpg
http://i538.photobucket.com/albums/ff346/rossyxyxyx/IMG00010-20090601-2124.jpg
http://i538.photobucket.com/albums/ff346/rossyxyxyx/IMG00013-20090601-2126.jpg
Message edited by Shadow703793 on 06-02-2009 at 03:45:59 AM
Reply to Shadow703793
Let me know when the rad is done. Then it's done. Youll be able to lose at least 4' of tubing once the rad is right off the back.
Message edited by Conumdrum on 06-02-2009 at 07:39:23 AM
Reply to Conumdrum
Its a XSPC Delta V3 block with an XSPC RS360 Rad 450ml res with 12V pump and then just normal clear tubing and barbs, also Im probably not going to mount it on the front, Im most likely to put it on the top.
Message edited by xtream_ocer_intel_nvidia on 06-02-2009 at 09:25:26 AM
Reply to xtream_ocer_intel_nvidia
Why would you use antifreeze? Would it help in cooling at all?
------------------------------ e8400 @ 4.00 ghz (500x8)
Gigabyte ep45-ud3r
4 GB G.Skill ddr2-1000
Msi 8800 gts 512 oc
Reply to dmv915
Its to kill algae and other nasties ^^ :bounce:
Antifreeze doesn't kill nasties. It's a old holdover from long ago to prevent disimmilar metals from corroding. Modern loops don't need it anymore. Some still use it, it doesn't help a loop, but it doesn't hurt it.
I expect the dye to be gone in 2-3 months and possibly chunks to be in the block.
http://www.overclock.net/water-coo [...] hy-my.html
Reply to Conumdrum
ok, when that happens I will break it down (with what?) nad I will also put in some PT nuke :bounce:
How do I embed pictures?
Message edited by xtream_ocer_intel_nvidia on 06-02-2009 at 08:54:03 PM
There are 1125 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
