Hello
I've started building a new system because my old system stopped wanting to boot. There was no motherboard beep or display when starting. I figured either the motherboard or CPU had worn out
I figured it was time for an upgrade anyway, so I bought this barebone kit:
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=3905996&Sku=A455-2812 H
I transfered over my, CPU fan, video card, sound card, hard drives, and DVD drive from the old system.
After putting it all together, I was greated by the exact same problem. No display, no beeps. The fans are spinning, but ocaisionally they will stop spinning after a few seconds. It did start once, the first time, but never since then.
My system is the link above...plus
-2 maxtor IDE drives
-1 DVD-RW drive
-XFX Geforce 8600 GTS
-Sound Blaster X-Fi Platinum (with live drive)
-The CPU fan that came with the Athlon X2 4800+ I had before.
Because the fans stop spinning leads me to beleive there is a power problem. I've tried 2 different power supplies however, one 2 weeks old, one brand new. The only thing I can think of is that there is a short curcuit somewhere.
Thanks in advance for any advice.
-1 DVD-RW drive
