Tom's Hardware > Forum > Homebuilt Systems > New System Build > New System Build criticism helpful
Forum Homebuilt Systems : New System Build - New System Build criticism helpful
This is for mild to medium gaming, watching HD Movies entertainment in addition to that i do mild to medium graphic design, Photoshop c4d ext . i am looking to spend about 1500 but can go as High as 1700
MoBo
EVGA 132-CK-NF78-A1 LGA 775 NVIDIA nForce 780i SLI ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Prod [...] 6813188024
CPU
Intel Core 2 Quad Q9450 Yorkfield 2.66GHz 12MB L2 Cache LGA 775 95W Quad-Core Processor - Retail
http://www.newegg.com/Product/Prod [...] 6819115042
HD
Seagate SV35.3 ST3750330SV 750GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Prod [...] 6822148302
RAM
G.SKILL 8GB (4 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Quad Kit Desktop Memory - Retail
http://www.newegg.com/Product/Prod [...] 6820231151
Vid Card
EVGA 01G-P3-N897-A3 GeForce 9800 GX2 SSC 1GB 512-bit GDDR3 PCI Express 2.0 x16
http://www.newegg.com/Product/Prod [...] 6814130355
PSU
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V Power Supply 100 - 240 V UL, CE, CB, TUV, FCC, CCC - Retail
http://www.newegg.com/Product/Prod [...] 6817139006
Case
ABS Aplus ABS-CS-EL Diablo Black 0.8mm SECC ATX Full Tower Computer Case - Retail
http://www.newegg.com/Product/Prod [...] 6811215006
Drive
SAMSUNG Black 20X DVD+R
http://www.newegg.com/Product/Prod [...] 6827151153
as for CPU cooling i have yet to decide on which one i will need, my room runs about 53, so i am not sure what type of cooling will be needed, also this rig will be running Vista ultimate 64 bit
Sponsored Links
Since you are not going to SLI with that video card you don't need to buy an SLI motherboard. nVidia's SLI chipsets are buggy and have many issues (just search this forum) not found on Intel chipset motherboard.
I would look at MSI Neo-3R P45 motherboard instead for $119.
Other than that nice build. You *might* want to consider 48x0 cards also. 4850CF gives 9800GX2 a run for its money, and beats it in some cases. 4870 CF should beat it easily in the same price range ~ $500.
CPU Cooler: http://www.newegg.com/Product/Prod [...] 6835233003 One of the best air coolers on the market.
Message edited by shadowduck on 06-21-2008 at 03:34:14 AM
------------------------------ http://www.tomshardware.com/forum/ [...] ate-modode <-- Computer Builds
Success comes from knowing that you did your best to become the best that you are capable of becoming."-John Wooden
Reply to shadowduck
- 0 +
actually i was looking for a VID card that was in the 3-4 hundred price range, i changed my motherbord to the
MSI P45 Neo3-FR LGA 775 Intel P45 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Prod [...] 6813130180
Reply to Zafar-M
4850 is a STEAL for $199. You don't need to spend $400 anymore :)
However, if you feel you must buy 2 and CF them on a x48 motherboard. :)
Message edited by shadowduck on 06-21-2008 at 04:08:28 AM
Reply to shadowduck
- 0 +
u have a link for that
Reply to Zafar-M
Reply to shadowduck
There are 1287 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
