The default RAM voltage for DDR2 is 1.8V. The default NB voltage is 1.25.
To double check the NB Voltage go into the BIOS and highlite the northbridge voltage and on the right it will say default vlotage.
The default CPU voltage depends on the VID of the CPU.
1Haplo
