Ok so I am looking to build my first "Dream Machine". I have all the parts I want to put in and I know how to build it, I just need to know what kind of power supply I will need to handle all of this. Here are the specs:
MotherBoard: BIOSTAR TForce TP43D2A7 LGA 775 Intel P43 ATX Intel Motherboard
CPU: Intel Core 2 Duo E8500 Wolfdale 3.16GHz LGA 775 65W Dual-Core Processor
Case: APEVIA X-TELSTAR-BL
Video Card: BIOSTAR V9603GT52 GeForce 9600 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
Ram: G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory
Hard Drive: Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
DVD Drive (optical drive): ASUS 20X DVD±R DVD Burner with LightScribe Black SATA Model DRW-2014L1T
OS: Dunno if you need this.. but if it helps... Microsoft Windows XP Professional SP3 English for System Builders 1 Pack CD - OEM
Ok so can anyone tell me how big of a power supply I will need? The one I had picked out was a APEVIA ATX-CW500WP4 500W ATX Power Supply but I don't know if that will be enough power. Also while you're at it could you please tell me if any of that stuff is incompatible with each other? I have decent tech knowledge but I don't know the specifics enough to know if all of this will work together. So any high level tech or tech that knows what they are talking about, help me please.
Thank you
Thank you
