Tom's Hardware > Forum > Storage > Hard Disks > Is a 500GB Hard drive faster then a 80 GB hard drive?
Lets say you have a 500 GB hard drive and a 80 GB hard drive. If both have 60 gigs of used space. Will the 500 GB one be faster or better in any way (If space is not an issue)? Cause I know when you get lots of things on your computer it takes longer to acess what you are trying to reach, Thanks!
Sponsored Links
Depends, if the 80GB have the data more organized that the 500GB, the 80GB could be more faster, or the contrary. In other words, if the 80GB is less fragmented that the 500GB, the HDD with less data fragmented is more faster.
------------------------------ If you like my answer, select me as the best answer.
"Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.". Albert Einstein.
Reply to saint19
Alright so the 500GB and 80GB will be exactly the same till it goes past 80GB then the 500GB will take longer to acess things past that right (If it is something that I have not used in a while and it is past the 80GB part on the 500GB)? Sorry for being so confusing I am having trouble explaining what I am trying to say.
Reply to Daniel5478
500GB, more capacity means less seeking if u use only 60GB. Plus a 500GB disk is of a newer generation than 80GB disk; so the data density is like 4 x higher and thus the speeds as well.
------------------------------ ...man will occasionally stumble over the truth, but usually manages to pick himself up, walk over or around it, and carry on.
Reply to sub mesa
Right, in this case the speed depends from the used space, obviously the 500GB is more faster that the 80 'cause have more cache memory, and the data are save in the firts clusters of the disk, while in the 80GB the data are save in the cluster that have space available.
Reply to saint19
500GB disk would have 250GB platters
80GB disk could have 40GB platters, meaning more than 4 x higher data density for the 500GB. This means the 500GB is about 4 x faster as well, in sequential transfers.
Reply to sub mesa
There are 911 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
  • 01:32 aford10 won the Home Brew badge
  • 01:00 Kevinator won the Uniformed badge
  • 01:00 adis won the Uniformed badge
  • 01:00 dabell won the Uniformed badge
  • 01:00 zebo56 won the Uniformed badge
  • 01:00 drkkmittal won the Uniformed badge
  • 01:00 jakesvdyk won the Uniformed badge
  • 01:00 artistjane won the Uniformed badge
