Tom's Hardware > Forum > Storage > Hard Disks > WD hard drives problems
I have 2 WD hard drives( 1 TB and a 500GB) that are not showing on My Computer any more.It just stopped showing. When I plug the USB cable in, Windows recognizes that the device is there; it loads the drivers and says that the device is ready to use. However, the drive does not appear in My Computer. Also, I have right-clicked on my computer and then the Manage option, and under Disk Management, I do not see the drive. I have the same problem with both drives. I have changed usb cables, tried different computers with different ops(Vista, Window 7 and XP), reboot it and it always have the same problem. I have a lot of important software on both drives. I need your help to at least get all my documents safe
Sponsored Links
Remove the drives from the enclosure and hook them up directly to a computer.
Reply to evongugg
There are 938 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
  • 01:32 aford10 won the Home Brew badge
  • 01:00 Kevinator won the Uniformed badge
  • 01:00 adis won the Uniformed badge
  • 01:00 dabell won the Uniformed badge
  • 01:00 zebo56 won the Uniformed badge
  • 01:00 drkkmittal won the Uniformed badge
  • 01:00 jakesvdyk won the Uniformed badge
  • 01:00 artistjane won the Uniformed badge
