hey guys, this might be a newbie question. But i am trying to get a workstation type computer for 3d rendering and graphics applications. But at the same time I would like to be able to do some gaming on it. Does anyone know of a motherboard that can support 2 cpus and also have sli or crossfire capabilities? Thanks alot in advance!
I would doublecheck with a reseller (or autodesk, but I find the VAR"s are far more helpful), I know of a few Autodesk applications that are capped at 4 cores. Unfortuantely the products I am more familair with are on the Civil engineering side (i.e. Revit, Civil3D, etc), but I'm pretty sure 3DS will sue more than 4.
For what (it sounds like) you are looking at I would make sure to get a 64 bit OS with tons of RAM (8GB maybe, I'm assuming your projects are complex).
