I orderd 2 4850s for myself and my brother. My friend Bob also got one. We just recieved them and are having major problems. First off my videocard hoggs 3gb of ram. I know this cause when I install my old x800 it doesnt. Not only that but my CPU usage goes from 0% for the x800 card to 30% with the 4850. Games arnt even playable. My brother's computer has a gigabyte mobo but still has the memory problem yet his CPU stays at 0% usage. I have an Abit mobo so I know its the cards. The cards are by Asus.
Ive done a fresh reformat with no luck. Im running 64bit vista but my frined Bob is using 32bit vista and still has the same proble.
Why does everybody else on newegg say the card is perfect when im having so many issues?
Bro's system
Mobo Gigabyte Ga-ex38-DS4
CPU E8400
PSU Antec 400w
Memory 4gb G -Skill
This problem occurs with a fresh install of vista 64bit before any drivers are installed and even with the drivers installed it still has problems. Im A+ certified and have had lots of experience in computers but this is just unbelievable.
With the x800gt installed I have no problems but with the 4850 installed windows keeps hogging ram till it gets to 2882 cached then stops with only 165 mb free ram. On only my computer does the CPU usage go up to 30% but this does not occur on my brothers computer with the gigabyte mobo.
is 500 or even 400w enough power to run these cards??? I would think no but I'm sure ATI has some "recommended" minimum power requirements on their site, you may want to check that.
Yes i do have a 6 pin power connector to my video card. The PSU actually comes with two 6 pin power connectors.
My friend Bob just message me saying its cause of superfetch and that vista is made to use all your ram as a cache but that doesnt explain why when i use a x800gt card my computer only uses 700mg of ram.
Lol I ran these cards in crossfire when I first got them and it didnt crash. I think the recommended PSU for crossfire is 550w with dedicated 6 pin connectors
Yes I installed the mobo driver from the manufacturers website. I think I fixed the problem with my brothers computer. All i did was disable the superfetch service in vista. Now it uses only 771 mb instead of 3gb. According to my friend bob his visiontek didnt have the same problem the ausus 4850 did with superfetch enabled.
Now I just have to figure out why my CPU usage jumps after installing the 4850 in my computer with the abit mobo
When you install a fresh copy of Vista, it takes a while for the OS to "calm down". Let it do what it needs to do and after a couple of days you should notice the OS behaving a little better.
Keep in mind that your video card does not use computer memory. It has it's own memory. Unless there is a driver bug, it's just a fluke in my opinion.
I installed a 4850 yesterday and I'm running Vista 32bit. I haven't noticed anything strange yet. I did not reinstall Vista. I'm also using the Catalyst 8.6 Hotfix drivers. The card works well.
Im not the sharpest marble on the block but I have learned to remove the Nvidia, Ati drivers from "add and remove programs" ,Reboot and use a tool like Nasty file Remover,( check it out, it still finds files after removal). Then install the new drivers.
Message edited by knotknut on 07-10-2008 at 10:36:21 PM
Thx guys but I already fixed the memory problem. All i did was disable the superfetch in services and that droped the memory usage from 3 GB to 771 MB!!! Now i have the issue regarding my CPU usage keeping a 30% load at all times. I read a forum where a guy had the same issue due to installing realtek audio drivers so im going to disable my sound card.
I would turn Superfetch back on and let it run overnight, or maybe two nights until it's finished doing it's thing. I would look into the 30% usage issue first though.
Another idea is give the 8.6 Hotfix drivers a try (if you haven't yet) and see if it makes a difference.
It might not be related to the new video card at all. Maybe sense it's a new install of vista it is re indexing everything, which could explain the cpu usage. Try turning indexing off and see if it makes a difference
Tried it, but it didnt work. Thanks for the input tho. Ive done more trouble shooting.
Ive tried disabling everything including audio,ethernet,usb, and sata contollers
Ive tried going into safe mode but problem is still present.
Ive tried switching pci e slots.
Now when i put the x800 in it has the same problem so i think the problem may be the microsoft pnp driver.
Vista is known to keep itself busy for a couple of days after a fresh install. Just let it be. If after a week you still have this problem, call Microsoft and ask them.
BTW, have you installed SP1 and all the security updates? I wouldn't be surprized if it's quietly downloading patches in the background as we speak.
Yes I have tried it with SP1 and still get the CPU usage problem. It is not updating windows and superfetch and indexing are disabled. I have a e8400 thats 3ghz and the gpu makes it use 30% of it but only one of the cores so its actually at 85% but the other core is at 0%.
I have had the 4850 in so long and tried so many troubleshooting steps that when i pluged the old 6600gt (nvidia) or the x800gt(ati) card the processor is still at 30% usage. This is good now im getting somewhere. This means that the problem is its software and it has something to do with vista installing a faulty driver for my unique configuration.
Yes games are definitly unplable becuase only one cpu is used at 85% which makes it hard for programs to utilize cpu.
GUYS... I just uninstalled my pci device driver in device manager and BAM! No CPU usage. Now my mouse and everything doesnt work but Im getting one step closer to the problem. Is there other drivers for the PCI device
OMG you guys will never believe how I fixed the problem
Basically it was due to the onboard sound on my motherboard, when I uninstall both audio drivers from the sound video and game controllers section of device manager it doesnt change the cpu usage but when u go under system devices and disable those high definition audio controllers BAM cpu drops to 0% right away.
This is definitely the hardest diagnostic I have ever done and I own my own computer business. LOL
