Tom's Hardware Forums » Graphic & Displays » ATI » The 4850 fan speed workaround doesn't work for me
Add a reply
 Word :   Username :
Bottom
Author
 Thread : The 4850 fan speed workaround doesn't work for me
Profile: journeyman
More Information
I got 2 Gigabyte 4580s in cross fire , running at an amazingly retarded fan speed of 22% (16 in the old drivers)
A workaround was posted to control fan speed through editing the catalyst profile.
I edit the profile, set the algorithm to Manual, and then the fan speed percent which i tried at 30, 60 , 80 and a 100 percent.
I know it works for a lot of people , but for some reason , i load the edited profile , and no change whatsoever, if i save it again , its back to the original percentage.
There's a FanSpeedAlgorithm and percentage _0, and _1 , one for each card, and i set them both.
My room temps are also retarded, so am idling around 78-82C
I haven't even attempted gaming, i don't wanna throttle the bloody cards
Any suggestions or further editing to the xml file are welcome
Should I try disconnecting one of the cards and do the fan speed thing on the other one ?
And How long do I have to wait for ATI to update their catalyst so that the drivers would be fully supported, will that be the 8.7 in a few days ?
Message quoted 1 times
Message edited by MOSDAPWN on 07-11-2008 at 05:06:10 AM
Related Pr oduct
Profile: Forum Veteran
More Information
This is where I found the tweak:
http://www.rage3d.com/BOARD/showthread.php?t=33926633
This part is what I changed. FWIW, I edited the file.xml named after my account instead of creating one & loading it at startup. Basically, this profile loads at startup by default.
Code :
  1. <Feature name="FanSpeedAlgorithm_0">
  2.           <Property name="FanSpeedAlgorithm" value="Manual" />
  3.         </Feature>
  4.         <Feature name="FanSpeedRPMTarget_0">
  5.           <Property name="Want" value="0" />
  6.         </Feature>
  7.         <Feature name="FanSpeedPercentTarget_0">
  8.           <Property name="Want" value="40" />
Profile: old hand
More Information
Well, although I don't like the high temps, I believe they are fine. You could try gaming if you'd like as long as you have good case airflow.
As for 8.7 fixing it, that would be nice. I know 8.7 beta didn't have it, but it has been a long time since then and I hope they'd have it on the release drivers.
What I can say, though, is that at 55% fan speeds these cards run nice and cool (yay Asus software).
Message edited by EXT64 on 07-11-2008 at 04:10:06 PM
Gaming: FX-60 @ 2.81GHz (x14, 1.375, 90nm) > A8N-SLI Deluxe > Asus 4850 - 625/1986 > 2GB Corsair XMS 400MHz
2-3-3-6-1T
HTPC/Light Gaming: X2 5400+ 2.8GHz Brisbane > Gigabyte 780G MATX - 900MHz Core > 2GB Corsair XMS2 800MHz
4-4-4-12-2T
Profile: journeyman
More Information
fixed the thing , reinstalled catalyst.Turns out there was a problem with all the overdrive, figured that out when i tried to oc the cards just abit, the sliders went back to where they were set. the overdrive functions were locked to default somehow and kept resseting what you did ... kinda strange ..
reinstalled catalyst , unlocked again, set the xml worked like a charm
btw .. 50+ on the fan is noise torture
Gigabyte P35-DQ6 | Custom Cooling / Gigabyte Block
XFX 8800 GTX @ 650/1550/2020 (RMA'D , people at warranty are givin me a hard time)
Q6600 G0 @ 4 Ghz @ 1.5v
2x 1GB HyperX 1066 @ 890Mhz @ 4-4-4-12.
werd.
Profile: addict
More Information
Would it be possible to get some smarter room temps?
Message edited by doomsdayda ve11 on 07-12-2008 at 04:04:11 AM
"Steve Jobs is not making enough money"
E8400|4GB|HD4870
Profile: stranger
More Information
For this to work, the Overdrive section of the Catalyst Control Centre has to be unlocked.
Profile: old hand
More Information
yea, i had the same problem, until i unlock OD. however i have just bought a third part cooler so it isnt to loud. i think ATi have messed up with this under spec cooler.
Add a reply
Google Ads
