I'm afraid becuase now there is a very little gap between these 2 cards,
3-6 mm. For now, i hav removed my cover to reduce the heat generation, but I still afraid of getting fry my sound card in the long term use.
Fortunately my proc is C2D E4500 which doesn't heat much.
Can somebody share his experience who is using both pci-e slots? Is this heat bearable and totally normal situation?
As long as your case has enough airflow, you should have no problems.
I would think your 8800GT's fan sucking air past the sound card would keep it more than cool enough.
------------------------------If the automobile had followed the same development cycle as the computer, a Rolls-Royce today would cost $100, get a million miles to the gallon, and explode once a year, killing everyone inside.
PSA
Reply to outlw6669
Hi all, Its me again and now I'm having a problem.
I used to play crysis at max settings + 2xAA before I buy my pci ex sound card. There were no problem at all.
But yesterday I installed crysis again and .... after couple of minutes gameplay the VGA freezes.
Everest report my VGA goes around 97C. I tried after removing my side casing as wel, but no luck. Though I didn't check the heat after removing the sound card, I'm pretty sure that this is the problem. The heat has nowhere to go.
(I was playing far cry 2 at max, GTA 4 @ medium, NFS undercover at max without any problem. VGA usually goes max to 93)
VGA fan is wired with 2 wires so I cannot change the fan speed as well. it runs @ 100%.
Does anybody have a clue of what should I do now?
What card are you using because 9800GT's get very hot so my guess is that you're using a 98GT, if so I think the best idea would be to get Duorbs.
Its a 8800GT. Though they have almost same specs i'm not sure about sizes.
I'm wondering anyone out there haven't got an experience like this. because many pci-e sound cards available there such as asus xonar/ creative and many other hotter vga cards out there such as ultra editions :-?
