Tom's Hardware Forums » Graphic & Displays » Graphics Cards » would the power supply be the problem with these graphic & component?
Add a reply
 Word :   Username :
Bottom
Author
 Thread : would the power supply be the problem with these graphic & component?
Profile: stranger
More Information
hi all,
i decide to buy this customized computer
http://www.ibuypower.com/ibp/store [...] 239#header
however, my friend told me that the power supply should be at least 700w up
should i upgrade my power supply? or this 680w is fine for readeon 4850 already
thank you so much,
Related Pr oduct
Some call me ... Tim?
Profile: enthusiast
More Information
That link doesn't work. If it's a single 4850, most 680W powersupplies will more than do the job. For info on how to determine how good a power supply is, check this article: http://www.tomshardware.com/forum/ [...] wer-supply
Profile: nimble knuckle
More Information
A budget no name 680 watt PSU wouldn't be much good, and neither would a 700watt budget PSU. There are certain companies that are really good PSU vendors: Antec, Enermax, Seasonic, Thermaltake, Corsair etc.
Here's a good site for PSU reviews and information:
http://www.jonnyguru.com/
A budget PSU from a no name company like Raidmax might work, but it has cheaper components and experiences a higher failure rate. I try to read reviews of PSU's that I buy, and the last time I bought a barebones system, I switched out the Raidmax PSU for an Antec True Power.
Overall, the financial way of determining if you have a good PSU is to spend at least $79, the old fashioned heft way is to hold it in your hand and note how heavy it is compared to a similar wattage no name brand.
You need to make sure you have enough amps on the 12 volt rail for your card. Check at AMD/ATI for recommended PSU's and check under each card's specs for how many amps it needs. Here's the page:
http://ati.amd.com/products/certif [...] html#pstop
Overall, a 680 watt and a 700 watt are comparable. ATI's site lists some 550 watt PSU's that are certified with the 4850, so it depends on what else you have in your system. Make sure your case has enough cooling, because the 4850 doesn't vent the hot air out of the case.
Bad cooling can lead to the card overheating, as the case air gets too hot. If you have a budget case, you might want to save up and get the 4870 instead, but make sure the PSU is good to go, or swap it out for a better one.
Me, I love the Antec Nine Hundred, can't get better case cooling than that!
http://www.xbitlabs.com/articles/o [...] undup.html
I know, you already bought the PC, but when you build in the future, consider cases that really keep your components cool.
Athlon X2 4600+ MSI K9AGM2 690V 2 gigs Kingston DDR2 800 MSI 3870x2 850/901 100 gig Maxtor SATA 2x 160 gig WD SATA 400 gig Seagate IDE Memorex DVD R/RW Antec Neo 650 PSU Antec Nine Hundred case.
Add a reply
Google Ads
