Tom's Hardware > Forum > Home Theatre > HDTV > SAMSUNG DLP PROBLEM VERTICAL LINES HLP4663W
Forum Home Theatre : HDTV - SAMSUNG DLP PROBLEM VERTICAL LINES HLP4663W
Archived from groups: alt.tv.tech.hdtv (More info?)
I have a new (refurbished) Samsung DLP: HLP4663W. The set displays
faint green / yellow vertical lines spaced evenly about two inchs apart
across the screen. They are only visible with shaded backgrounds and
are bleached out in bright scenes. Faint but anoying problem.They are
consistent with various program sources ... so I suspect the set or DLP
chip. Does anyone have an insight into this problem and how to fix it.
Sponsored Links
There are 853 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
