Evening all,
I'm looking into buying a psu for my next build, which will look something like this:
P45 motherboard
4gb pc6400 ram
2 sata hard -drives
2 optical drives
quad core ( probably q6600 )
ati 4870
Its a bit vague, but thats because I'm having to buy a new PSU as my old one just went, and i dont have the money for all of the above just yet and as such not decided on it all.
Anyway I've been looking at the Corsair TX 750, and read fairly good things about it, but i need some advice. Will it be able to power the above system with an overclock on the q6600 lets say to 3.6 and be able to power another 4870 should i later decide to crossfire?
Also to any current owners of it, how noisy is it, and have any of you removed the plastic covering half the fan, if so did it have any effect on temp/noise
My current build is
Nforce4
AMD 3000+
1gb pc3200
Nvidia 6600
1 hard-drive
2 optical drives
I assume it'd have no problems with my current pc too.
Thanks in advance for your help!
P45 motherboard
4gb pc6400 ram
2 sata hard -drives
2 optical drives
ati 4870
My current build is
Nforce4
AMD 3000+
1gb pc3200
Nvidia 6600
1 hard-drive
2 optical drives
