Is Extreme processor worth it without water cooling?
Last response: in CPUs
Related ressources
I would never pay for an extreme either.
The current line of CPUs overclock just as good and as high as the Extreme CPUS.
Besides when you up the FSB on a locked multiplier you get a faster overall system then a extreme with a lower FSB.
Look at what's on the market now: Two processors with identical cores, made on the same production technology, most likely from the same portion of the same silicon wafer. One is labeled Q9650 and cost $550, the other is labeled QX9650 and cost $1050. The differences? The QX has it's mulitiplier unlucked upwards, and it cost $500 more.
You don't need unlocked multipliers to overclock, so makes an "Extreme" processor worth so much more money? Nada.
Ask the community
