Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > I have a problem...well I think it's a problem
I want to buy an ati 3870/3850.Now the problem(if it actually is) is that the graphic card is long and it will touch a piece(I think atleast) on the motherboard,the piece is cylindrical in shape.
I have a MSI MS-7046 motherboard.
Here's a picture:http://img233.imageshack.us/img233/6462/ms7046to3.th.jpg
The black cylindrical thing,I think it will be right over it.So would that be a problem?Or it's just me?
Sponsored Links
You should be fine, the card will sit above the capacitors.
Reply to dirtmountain
Yes but wont it heat up or something if it touches it?
Well I guess I'll need to try one out to see.
Reply to buutenks2
The black cylindrical thing is a capacitor.
Your graphics card will go in the black slot. You have to lock the card in place with the white clip. That clip when locked is higher than the capacitor. So I don't think there will be a problem. On some motherboards the graphics card extends over the SATA connectors.
You can use Google to search for pictures of an 3870/3850. On some pictures you can see that the card doesn't touch any components on the motherboard.
Reply to FreeDuck
- 0 +
thats normal...the motherboard manufactures are aware of it when they make it...usually happens on most boards
Reply to mbbs20
yeah it should be a couple mm's above the capacitor, as for heat, you shouldn;t be too concerned
Reply to eklipz330
Ahh okay then,thank you all.
Reply to buutenks2
There are 473 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
