i've got an a8n32 sli that has worked perfectly until recently. i used automatic update and after installing it wanted me to reboot. so i reboot the pc and when it got back to the windows xp logo i got a bsod.
after a while i finally figured out that if i use a PS2 mouse instead of a USB mouse it boots perfectly. as soon as i plug a USB mouse in i get the same bsod (something about the motherboard not being ACPI compliant).
strange thing is that i'm using a USB keyboard and a USB wireless internet drive and both of those work just fine.
this pc is running Windows XP SP2.
any help is greatly appreciated.
Unfortunately this is a known issue with the ASUS A8N32 and Windows XP SP3. ASUS have released a firmware update for the A8N motherboard (1409) however this didn't make any difference on the machine I upgraded. There are several workarounds however, see my reply on this thread for a cure:
I too have encountered this issue with my A8N32. I started getting the same BSOD when I added a 3rd SATA hard drive. I found a fix on-line but I have no idea why it works. It works for me though.
My rig boots Windows XP pro, Vista ultimate, or Windows 7. I only encounter the BSOD problem when booting into XP. I use a USB mouse and a USB keyboaard.
The fix I found was plugging a large USB flash drive into one of my USB ports. When I say large I mean larger than 2GB. I use an 8GB drive I had spare. I tried a 512MB drive and it did not work. Try booting with the USB flash drive plugged in. I just leave mine in a spare USB port in the back of my computer.
Why this works? Beats me.
By the way, I am running the very latest BIOS for my board. The release notes indicated that it would fix this (or a similar sounding problem) but the BIOS did not fix the problem I had.
Give it a try and let us know if it works for you.
