Tom's Hardware > Forum > Motherboards & Memory > Elitegroup > ECS mb won't post in new build. Help!
Forum Motherboards & Memory : Elitegroup - ECS mb won't post in new build. Help!
"Sure, I'll build my own PC, why not? How hard could it be?" Famous last words, right? :sarcastic:
Anyway, here are my stats:
Elitegroup A780GM-A motherboard
AMD Phenom X4 9950
Antec 300 case
4G Kingston DDR2 SDRAM (2G x 2)
500 power
...and a bunch of hard drives and DVD writers that don't seem to make a difference right now because I get the same symptoms whether they are connected or not.
Everything seems to power up okay. But I'm getting no picture out of the on-board VGA, and no beep when I power up. (The lack of beep isn't a surprise, because the case appears to have no speaker. Could that be right?)
As far as I can tell I've connceted everything where it is supposed to go, except for the case speaker. I've played around with the RAM in different slots, taken out and replaced the battery, tried a different monitor...no dice.
I left all the jumpers the way they were when I took the mobo out of the box. There are 3 3-pin jumpers for USB power controller, and all are set to VCC5 as opposed to 5VSB. But seeing as how I have no idea what those mean and I could find any info online, I'm not messing with them yet. :sarcastic:
Please please please...help! Thanks.
Sponsored Links
Some cases may have a tiny speaker like this behind the front panel:
http://www.clearpc.ca/catalog/images/speaker.JPG
It can be hooked up to the SPEAKER pinout on the mobo.
As for the unknown jumpers, look them up in the manual in the layout section. It's got to be numbered & explained on the same or next page. Then in the next section the use will be explained.
Try each stick of ram in each slot.
Reply to auscanzukus
Still no luck. Tried every configuration of RAM I could think of, and even tried 1G (2 x 500M) left over from my old computer, but I'm still getting no picture. Even weirder, I scavenged a speaker from an old case (my new one indeed has no speaker) and the mb won't beep. It's like the thing is in a coma, only sign of life is the case and CPU fans.
I also tried clearing the CMOS. Still nothing.
Oh BTW, I made an error earlier: The RAM isn't Kingston. I asked for Kingston, but the guy at the shop was out of stock, so I bought Super Talent instead.
Reply to Sulaco99
Super Talent is better for overclocking unless Kingston still uses Micron chips.
Try clearing cmos for 10 mins to overnight just in case. If no luck, rma the mobo & ram.
Let the CMOS clear overnight, and even tried taking out and reinstalling the CPU and heat sink. No dice.
Guess I've got a bad mb. What a drag. Thanks for your help, hopefully my next mb install will be smooth sailing.
Reply to Sulaco99
- 0 +
I'd say the problem is the power supply or the cpu. Some boards won't post with newer phenoms. You may need to flash the bios or try a different board.
Reply to o1die
Hey, this is interesting. I may have figured out why it's not working.
According to this article I found, the Phenom 9750 and 9850 require a 790 chipset on the mobo. I assume this applies to my Phenom 9950 as well:
http://technologyexpert.blogspot.c [...] board.html
But according to the specs, my mobo has a 780G chipset:
http://www.newegg.com/Product/Prod [...] 6813135075
Would this explain why I can't get the mobo to post?
I assumed this CPU would work with this mobo because newegg offered them both in a discounted package deal, but now I'm wondering if they goofed.
Reply to Sulaco99
Everybody calls themselves an expert in a blog these days. I would take them with a grain of salt.
Not sure who recommended the mobo & cpu to you, but the mobo doesn't support the cpu:
http://www.ecsusa.com/ECSWebSite/S [...] 69&LanID=9
Both versions. Wrong board. You have to make sure the mobo supports the cpu before purchase.
I thought I did, newegg was selling em both together as a package. Guess I'll have to be more careful than I thought.
Reply to Sulaco99
the ECS Blackseries motherboards dont support 125watt+ CPU
no newegg is not selling them as combo, they are selling the biostar and foxccon that do work with that cpu based on the 780gx chipset
Message edited by fireshroom on 09-16-2008 at 12:47:51 AM
Reply to fireshroom
There are 1095 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
