I have a question on if the power supply I have is big enough for my system. I have a amd 5000 be , 1 4850 , dvd rom ,dvd rw,4 gig ddr2, and 1 hard drive on a msi am2 790x motherboard. I am looking into getting another 4850 to run in crossfire and going with a amd phenom 9850. The power supply that I have is an antec 550w true power 2.0.
Now the only thing that i found is that a 4850 requires in crossfire a 550 w or greater power supply but with a 125w cpu is my 550w enough i dont find anything stating what setup is used when figuring there requirments to say 550w or better
Only a fraction of total wattage is routed to the 12v rail that powers graphics card, cpu, hdds. Also, even the most efficient psu has around 80% efficiency under optimal conditions. Under typical usage, it's lower. Effect of aging and ampage limitations also cut down power available in reality. Depending on 12v rail ampage and fluctuation at high load, 550w is cutting it very close, if it works at all.
Message edited by dagger on 07-12-2008 at 05:11:55 PM
I would recommend Thermaltake, OCZ, or Corsair of 650+ Wattage. Although you can get cheaper power supplies that state higher wattages; it is all about the brand, and efficiency of the PSU. Stick with a decent brand, and 650+ watts, and you are good.
