Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > 8600 gts power consumption
Forum Graphic & Displays : Graphics Cards - 8600 gts power consumption
hi all,
i'm running an htpc with:
epox 9npa mobo
amd athlon 64 3200
1gb ram
120 sata harddrive
dvd burner
my psu died a month ago, so being on a limited budget i ordered this 480w:
http://www.newegg.com/Product/Prod [...] 6817170012
and life was good again.
then, last week my gpu fan (7600gs) died. so, i ordered a 8600 gts (i do very light gaming on this thing).
...and now the computer doesn't turn on at all...no lights, no fans, nothing. my question to you guys is do you think my psu is poweful enough for the 8600? i'm tempted to think maybe not, since the 7600 just drew power from the slot and the 8600 has an aux power input. Even so, it should have the necessary watts and amps, no?
i know you're not supposed to, but i also tried it without the aux, and still nothing.
i thought maybe the card was bad, but it shouldn't prevent the machine from at least turning on, should it?
thanks for the help.
Sponsored Links
12v rail ampage is very weak, but should still be enough. Likely defective hardware, either psu or card itself.
------------------------------ Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Reply to dagger
is there somewhere i can verify 12v is enough??
Reply to cronus98
That PSU has a 12v rail amperage comparable to a quality 250watt psu, but it should still handle it, barely. That would be the most obvious problem that I can see.
Comparison:
http://www.newegg.com/Product/Prod [...] 6817703018
that PSU is only 370watt, but it has 27amps on the 12v.
The one you have is 480 watts, but only 16amps on the 12v. So the one above would be much more capable even though it has a lower wattage rating. here would be a cheap, quality PSU:
http://www.newegg.com/Product/Prod [...] 6817153060
Unless somebody can find him a better deal.
------------------------------ // Intel C2D E6750 @ 3.2ghz 1.35v // Asus P5K P35 // 2gb Patriot 1000mhz // Sapphire HD4850 @700core 1100mem // Antec neo 500 HE // Antec 900 // SB X-FI // WD 250gb Sata-2 //
Reply to terror112
It will handle it, friend of mine has **** 500w psu, those grey ones, and a load of hdds, works fine. Try to test the card in another pc
Reply to blackwidow_rsa
thanks for the help guys.
Reply to cronus98
There are 638 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
