Hello, I just recently bought a new wireless N router, and I have 1 computer, a 360 a wii and a PS3. Since the consoles don't have Wireless N capabilities, how do you connect it via N. (My router supports G, but I want N speeds) Is there a way I can get another router, and connect it to my other router that are both N, and connect the electronics in my room physically instead of wirelessly? If so, how can I do this??, and could you tell me a product I could use?
Thank you soo much.
f1racer8292
Message edited by f1racer8292 on 01-31-2009 at 11:45:11 PM
You will never get 'N speeds' on G hardware. The 802.11g supports max. 54 Mbps; this is defined in the standard and can never be more.
If your N-router supports 802.11g then there is no need for a second router.....I would hook up the consoles to a switch. Connect the switch to the N-router. That should work.
Your switch ports should be FastEthernet (100 Mbps) or else you are stuck at 10 Mbps
Message edited by ThePatriot on 02-15-2009 at 03:09:46 PM
