Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > My 9800pro AGP died and I need major help
Forum Graphic & Displays : Graphics Cards - My 9800pro AGP died and I need major help
Ok I have an older dell *yea I know its a Dell* and its an AGP system. My specs are:
Pentium 4 CPU 2.60 GHz
1 GB Ram
250w PSU
My 9800 pro had its fan die on me. I tried to buy a new fan at the cost of 12 to replace it but the connector to the fan is too big here are some pics:
Left side is the new one I bought http://img.photobucket.com/albums/ [...] G_0238.jpg
Left one is the one connector http://img.photobucket.com/albums/ [...] G_0237.jpg
NOw here are my fans:
bottom one is the replacement: http://img.photobucket.com/albums/ [...] G_0239.jpg
Since I dont feel like spending more money hopeing to find a fan that fits the connector to my card I think that I will just replace my 9800 pro AGP
I cannot afford to majorly upgrade my system or to replace it. So i'm looking for a good card thats better than my 9800pro but that will work on my system.
So far I'm stuck between these two cards:
http://www.newegg.com/Product/Prod [...] 6814102718
http://www.newegg.com/Product/Prod [...] 6814102073
Will my system be able to handle these two cards and if so which ones and how well do these cards work?
If none of these cards work will I be able to find a brand new ATi Radeon 9800 XT AGP card anywhere? Its a slight upgrade from my 9800pro.
Sponsored Links
I'd go with an AGP version of the X2600XT. You should check with the manufacturer regarding power supply requirements but I believe it would work with a decent 250 watt PSU. See Tom's charts for information:
http://www.tomshardware.com/review [...] 965-6.html
See the comment from the chart below:
Quote :
I don%u2019t recommend upgrading your graphics card unless the replacement card is at least three tiers higher. Otherwise, the upgrade is somewhat parallel, and you may not notice a worthwhile difference in performance.
The X1650 Pro is only 2 tiers higher, but the X2600XT is 5 tiers. The X1650 Pro only has 12 pixel pipelines (and your Radeon 9800 Pro has 8) but the newer architecture of the X2600XT has 120 stream processors, which probably equates to 16 pixel pipelines under the older architecture's definitions.
Another choice would be a 3650 DDR2 model. I have one in my wife's PC until we can afford a 4850 upgrade. It's in the same price range and is 4 tiers above your old 9800 Pro.
http://www.newegg.com/Product/Prod [...] 6814131097
That said, a couple of years ago, I replaced an All in Wonder 9800 Pro TV card with an X1650 Pro AGP and I went from medium settings in Oblivion to high. The X1650 Pro might be all you need, and is more likely to work with the power supply you have.
Still, I'd recommend the best card for your money, and that's the X2600XT but you might need to upgrade to a 350 watt, or higher power supply for it. For your PC, I'd recommend the Antec Earthwatts 430 at $59.
http://www.newegg.com/Product/Prod [...] 6817371006
If you don't upgrade your power supply, you might encounter problems. I had a generic 350 watt when I went from a 9800 Pro to an X1650 Pro, but the whole PC died in a thunderstorm. Could have been a spike on the power lines that the cheap power supply couldn't handle. Since then, I've always bought decent PSU's like Antec, Seasonic, Enermax etc.
Companies like Dell often skimp on power supplies, but they won't be as bad as a generic PSU in a barebones.
Message edited by yipsl on 07-13-2008 at 10:26:42 AM
------------------------------ Phenom 8750, ASUS M3A78T
4 gigs Kingston DDR2 800 two 1T SAMSUNG HD103UI
Sapphire 4870x2, Sony BDU-X10S BD-ROM
Antec Neo 650 PSU Antec Nine Hundred, Acer H213H 1080p LCD
Reply to yipsl
- 0 +
http://www.newegg.com/Product/Prod [...] 6814102751
x1650
$ 49.99
that or take a walk on the wild side
http://www.newegg.com/Product/Prod [...] 6814500029
7600gt with gddr3 59.99
the 7600 is the hands down winner
Reply to macer1
if the connector is the only problem you could just remove the connector from the old fan. Cut it off with about 3 inches to spare. Then cut the connector off of the new fan. strip the wires, twist them (black to black, red to red), then tape them up. end result will be new fan with old connector.
Or try this
http://www.newegg.com/Product/Prod [...] 9&Tpk=9800
Message quoted 1 times
Message edited by PsyKhiqZero on 07-13-2008 at 11:06:29 AM
Reply to PsyKhiqZero
^+1, ty I was gonna mention that, if somebody already didn't, just do that...spend no more money and just save your money, b/c it is a recession.
Reply to FrozenGpu
- 0 +
When I read the post the first thing I though was to splice them together but you guys beat me to it. Although you will see an improvement the problem with buying a newer card is that you will be bottlenecked by your CPU.
Message edited by ausch30 on 07-13-2008 at 01:38:03 PM
It is the mark of an educated mind to be able to entertain a thought without accepting it.
-Aristotle
Reply to ausch30
The funny thing is ATI recommends a 300watt PSU for the 9800 series. http://ati.amd.com/products/radeon [...] specs.html
One of these should help to decide:
http://support.asus.com/PowerSuppl [...] uage=en-us
http://extreme.outervision.com/psucalculatorlite.jsp
http://web.aanet.com.au/SnooP/psucalc.php
http://educations.newegg.com/tool/psucalc/index.html
I don't know what your budget is or how long you want to keep the system, but the HD 2600XT is a good choice. The HD2000 and HD3000 series will also get you better video processing capabilities with UVD. Not sure that matters to you, that puts the HD2600XT or a HD3580 as a better choice over previous generations.
Message edited by sslusser on 07-13-2008 at 02:38:14 PM
Reply to sslusser
- 0 +
macer1 wrote :
ps your PSU should be fine with the 7600gt
http://www.tomshardware.com/forum/ [...] ments-7600
He should not go Nvidia 7xxx generation. There are blurring issues that I noticed when we had a 7600gs in an X2 3800+ build with an Nvidia 405 chipset vs. the P4 with an X1650 Pro. It's a problem that Nvidia didn't fix until the 8xxx series.
As for the PSU, the Earthwatts is quality for not that much more. I wouldn't bother with splicing a connector on a 250 watt Dell PSU. Sometimes, the solutions people come up with here are more hobbyist than practical.
It makes more sense to get a new power supply that can power the system then to splice the connector on the old PSU. As for being CPU limited, I don't think his P4 would be overly taxed by an X2600XT. We aren't talking 3850 here. The card's he's considering came out when the P4 was still the most common processor in OEM builds.
Message edited by yipsl on 07-13-2008 at 05:09:05 PM
Reply to yipsl
Another route you could go is to get a silent cooler like this one: http://www.newegg.com/Product/Prod [...] 6835186017
No worry with the fan and its a $20 fix.
FYI:
HD2600XT > HD3650 => HD2600 pro > x1650.
I think we really need to see what the budget looks like. Sounds like its somewhere around $100 or so. Correct?
Check out one the power estimators I posted above. I did a generic P4 with a 9800 pro and then with the HD2600XT and a HD3650.
It came out to really close for all of them. So, I think the 250PSU will likely still work with the x1650,HD2600 or HD3650 cards.
I think this is the cheapest/best route to go for a new video card without the new PSU.
I did the 3850 and it jumped about 20watts, but it would be tough with your PSU and you'll need to know the amps for the voltage rails. This is likely out of the budget.
I definitely would rule out and X1600/1650 series cards, unless its an incredible deal. You also need to think about longevity. Is the plan to keep the computer running for another 3 years or buy completely new in 3 to 6 months? The longer you keep the system, the better a new PSU sounds.
Message edited by sslusser on 07-13-2008 at 07:19:07 PM
Reply to sslusser
yipsl i respect you very highly, but come on bro all he has to do is put the other connector on, i;ve done it b4 for VGA cards, cpu coolers, fans, etc etc etc, dude why spend money when it doesn't grow on trees, come on bro..come on..,
Reply to FrozenGpu
yeah we're not talking about splicing the PSU wires. just splicing the fan wires. I don't see where that is less practical then buying a brand new gpu and power supply for a system he will probably not keep for more then a year.
- 0 +
I think you misread yipsl, there talking about splicing the fan connector, not the PSU.
------------------------------ http://farm4.static.flickr.com/3073/2578392638_2827857d10_o.png
Reply to B-Unit
- 0 +
I'm a hardware noob so I have no clue on how to splice.
Reply to DrG
- 0 +
There is a red wire and a black wire. Cut them both and twist the like colors together and wrap some electrical tape around them. Now you have the correct connector on your new fan.
-Aristotle
Reply to ausch30
- 0 +
hmm I will give that a try
Reply to DrG
- 0 +
OK I have some splicing/getting my 9800 back up and running.
So I spliced on the new connector, I then spen 25 min or so trying to get the scew holes lined up to put the fan back onto my heat sink. I finally got one of the hole to line up then I put one screw in the fancan spin but I cant quite get the other 2 screw holes to line up so I cannot get 2 out of the 3 screws in.
So can I get by with just having 1 screw in? I mean can it hurt the fan?
Another question. HOw can I tell how cool the fan will keep the card?is there a program to check my card temp?
I put the spliced fan pack in and loaded it up and it does spin. I tried moving the fan around to see if it was loose but it seems to be in there tightly.
The new wire that connects the fan to the card is fairly long. Will it be a future problem for my card if I leave it long? I'm thinking it will be ok if I just make sure that the cord doesnt tough my card or get in the way of the fan.
Reply to DrG
- 0 +
You can use a program like RivaTuner to check you temps and if the fan isn't moving I think you'll be ok without the other screw. If the wires are a little long you can just cut them a little shorter and guess what you are officially a modder now.
-Aristotle
Reply to ausch30
- 0 +
It feels kinda cool to actually be able to do this myself.
Reply to DrG
- 0 +
That's what makes it such a fun hobby but be careful because it gets addictive. I don't bother putting my side panels on anymore because I'm always tinkering with something,lol.
-Aristotle
Reply to ausch30
- 0 +
Where can I get rivatuner from thats safe?
I tried to down load it but when I clicekd to down load I got this screen that wanted to extract from my temp internet files so I canceled the down load.
Reply to DrG
http://downloads.guru3d.com/
http://downloads.guru3d.com/RivaTu [...] d-163.html
I use this for a Radeon 9000. It has fan control and hardware monitoring also.
http://downloads.guru3d.com/ATI-Tr [...] d-733.html
Message edited by sslusser on 07-14-2008 at 06:00:49 PM
Reply to sslusser
- 0 +
If you plan on updating a PSU, make sure it will work with a Dell. Dell, in all their genius, used non standard PSU's in their PC for a long time.
Myself, Id just buy a replacement heatsink/fan for cheap. Save your coin for a new PC.
Reply to Kaldor
- 0 +
I down loaded that ATI tool but I cannot figure out how to see the temp of my videocard
I cant seem to download Riva I click to download it and have the downloader on my system but after downloading it I cant get any sort of program to come up
Message edited by DrG on 07-14-2008 at 07:45:02 PM
Reply to DrG
- 0 +
Ok I downloaded Riva *I think* but I cant get anything to show up. after downloading it I get a program called "RivaTuner209-[guru3D.com]
I launch it and it looks like it installs something but then no other program other than RivaTuner209-[guru3D.com]. I reclick that but it seems to just want to replace itself but other than that nothing happens.
Reply to DrG
- 0 +
I dont use it. But I do believe it runs down in your taskbar on your PC. You need to open it from there.
Reply to Kaldor
To get temps with ATI Tray Tools, Right click icon in task bar, put the mouse pointer over Hardware. Go down the list to System tray hardware monitoring. click on that and tick the box for GPU temp and Environment temp. You should choose a colour that contrasts with the task bar (obviously) :)
Mactronix
Reply to mactronix
- 0 +
Mactronix
Cant do it. Its grayed out. I cant choose a color
Reply to DrG
Ok then that sugests its not suported with your card. Try downloading GPUZ and when you run it open the sensors tab at the top and that should give you the temps.
Mactronix
Reply to mactronix
- 0 +
Mactronix
That app doesnt give any temp under that tab.
Reply to DrG
Got some bad news for you i did some checking and the GPU used in 9800 Pros didnt have an integrated temperature sensor. Some 256MB 9800 Pros were actually underclocked 9800XTs and they have external sensors next to the GPU but I think you have to flash them to a 9800XT BIOS before the temps show up. But we dont even know if yours has the XT chip or not. If the temperature isn't showing up then it's probably because you don't have the external sensor.
Sorry Mactronix :(
Reply to mactronix
I know a new card was ruled out, but I saw this today. Cheaper than the x1650.
http://www.bestbuy.com/site/olspag [...] 7112903079
Reply to sslusser
Ok, then what you do is you simply get more cooling on that card, to compensate for the fact that you have no clue as to what the temp is, just use a 120mm or 88 mm fan on that, or sue one of those pci slot cooling fans just read into how much cfm is actually being pushed out and you should be ok...
Reply to FrozenGpu
There are 837 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
