Tom's Hardware > Forum > Graphic & Displays > Nvidia > GX2 Heat Problem?
Good morning. I have just built a new gaming machine. When I play Crysis I see what I believe is artifacts. They show up about 30 mins of playing. I ran I video card stress test and got 88C for the card and 65C for the Cpu. Is this a normal temp? Do I need to cool my case better? If so how?
COOLER MASTER COSMOS 1000 CASE
EVGA GX2 SUPERCLOCKED VIDEO CARD
E8500 CORE 2 CPU
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
MUSHKIN RAM 2X2G
2 RAPTERS 36G
1 WD CAVIER 500G
I have installed all the fans I can in the case and have also installed the video card duct. Thanmks for any help.
Sponsored Links
You should bump up fan speed of the card itself. Try Rivatuner.
http://downloads.guru3d.com/download.php?det=163
Fan speed guide.
http://www.vaguetech.com/users/dwo [...] rivatuner/
------------------------------ Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Reply to dagger
Thanks for the reply. I tried your suggestion with no luck. I did hear the fan speed up but it did that automatically before. Anybody else?
Reply to tsnow
There are 1119 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
