Need a new System Build - for the high end gamer.
I wasnt sure if this is the right forum to post at but I will be happy to have some suggestions.
I need an entire full build for a new machine for the high end gamer.
I'd pay up to 2450 USD ($), a spertacular PC that will keep me satisfied for a long time and run smoothly everything I try to run on or atlesat most of.
I'd also like to know between the Dual SLI diffrences and their effect on the price.
Also please name witch card is better as between the 280GTX and the HD4870 2X.
Thanks alot.
Tom.
1 answer Last reply
More about need system build high gamer
    Thanks alot.
    Tom.
    This is what you want then for that money. It has dual 4870's (Crossfire), a X48 board, etc... This rig will eat up any game you throw at it including Crysis. Good case with great airfrlow/cooling for Crossfire and/or SLI (4x120mm case fans with room to add three more for a total of 7x120mm case fans), not to mention alot of room to work with. The PSU is more than enough to power it with room to spare incase you want to add more fans, HD's, etc... This is the rig Tom. :)
    btw, move up your FSB (Front Side Bus), to 8.5x400 = 3.4GHz.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137 $84.99
    COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835150070 $4.99
    MASSCOOL FD12025S1L3/4 120mm Case Fan - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817703013 $249.99
    PC Power & Cooling PPCT860 860W ATX12V / EPS12V Power Supply 100 - 240 V UL, cUL, CE, TUV, RoHS - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115041 $549.99
    Intel Core 2 Quad Q9550 Yorkfield 2.83GHz 12MB L2 Cache LGA 775 95W Quad-Core Processor - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835233001 $24.99 ($14.99 after $10.00 Mail-In Rebate)
    XIGMATEK HDT-S963 92mm Rifle CPU Cooler - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835233019 $6.99
    XIGMATEK ACK-I7751 Retention Bracket - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128336 $224.99
    GIGABYTE GA-X48-DS4 LGA 775 Intel X48 ATX Intel Motherboard - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820146785 $108.99 ($83.99 after $25.00 Mail-In Rebate )
    mushkin 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814161236 $309.99
    HIS Hightech H487F512P Radeon HD 4870 512MB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822136260 $299.99
    Western Digital VelociRaptor WD3000GLFS 300GB 10000 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827106057 $30.99
    LITE-ON Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA DVD Burner - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835186020&Tpk=mx-2 $6.99
    ARCTIC COOLING MX-2 Thermal Compound - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16832116204 $94.99
    Microsoft Windows Vista 64-Bit Home Premium for System Builders Single Pack DVD - OEM
    Total
    $2,308.86
    $2,273.86 w/ mail in rebates
    http://www.newegg.com/Product/Product.aspx?Item=N82E16824113012 $479.99
    Gateway FHD2400 Black-Silver 24" 3ms DVI Widescreen LCD Monitor w/ 4-port USB Hub and Height & Pivot Adjustments 400 cd/m2 1000:1 - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115042 $329.99
    Intel Core 2 Quad Q9450 Yorkfield 2.66GHz 12MB L2 Cache LGA 775 95W Quad-Core Processor - Retail
Build Systems Product
