Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Power supply for HD 4870. Any recommendation? Any good deal?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Power supply for HD 4870. Any recommendation? Any good deal?
Topic. I am looking for a PSU that can work with 4870 with a Q6600. Please don't recommend a very expensive CPU. I am on budget. Anyone know what's the amps needed for the 12v rail?
Thanks
Sponsored Links
http://www.newegg.com/Product/Prod [...] 6817139004
That's gonna hold your rig without any problems. It has +12V@41A, more than enough for a 4870.
Reply to iicsus
Thanks
Refer you to:
http://www.extreme.outervision.com/psucalculator.jsp
You need a 140Watt (= 12A 12V rail) for the 4870.
Don't forget the 4870 may not need a lot'a watts but it does need 2x GPU PCIe 6-pin power connectors. The cheap Antec PSUs (which are very good BTW) don't have this nor does the Corsair 450 VX.
Your best bet is the suggestion by iicsus.
Bob
Reply to bobwya
Will this work ? Antec earthwatts EA500 500W. http://www.newegg.com/Product/Prod [...] 6817371007
and if purchase with the Antec Three Hundred Black ATX Mid Tower Computer Case, it only cost $99.94.
Reply to ahtze
If you act today 8/15 here is the deal of the year.
PC Power & Cooling S61EPS 610W
Back to school special savings, ends 8/15
Original Price: $199.99
You Save: $90.00
$109.99
$79.99 after $30.00 Mail-In Rebate
Reply to Zorg
Theoretically yes (but the dual 12V rail might cause a problem)... That is a very good deal there...
Bob
Reply to bobwya
Zorg has a good suggestion. Another deal you could consider which has the connections you need is:
http://www.corsair.com/products/vx.aspx
http://www.buy.com/prod/corsair-vx [...] 52646.html
Corsair 550 @ 69.99 AR, free shipping FedEx.
Reply to ejay
There are 1259 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
