Tom's Hardware > Forum > Homebuilt Systems > New System Build > -= Energy Efficient Build (need help with) =-
Forum Homebuilt Systems : New System Build - -= Energy Efficient Build (need help with) =-
I've been trying to find parts for an energy efficient build and can use some help with what parts to use. It's going to end up being left on 24/7 and act as a file server. I intend to use Western Digital's GP drives as they seem to be quite efficient and has decent performance. My problem is finding reviews and charts with computers being rated for efficiency. Also finding some reviews for MoBo's with built in graphics. No one seems to be reviewing them anymore. :na:
Any help would be great.
MoBo (with graphics chipset built in)
Power supply (big deal and how many watts?)
Processor
RAM (don't think there's any reviews for RAM's energy efficiency is there? probably doesn't make that big of a difference either)
Hard drives (if anyone has a better suggestion other than WD's GP series please tell me =) )
thanks for any help again.
darzon
p.s. I should mention if possible I would like to use nothing but passive cooling, just case fans and not even a heat sink... if that's even possible with today's processors.
Message edited by nozradd on 06-26-2008 at 09:18:26 PM
Sponsored Links
Any guidance on your total budget? Usually the smaller and more efficient you get the higher the costs go.
How big a HDD do you need for your network storage? 2.5" laptop HDDs are among the most power efficient. In fact an older, recycled laptop would do a pretty good job acting as an energy efficient file server.
What else do you need besides MB & IGP, PSU, CPU, RAM and HDD?
Case?
Have you looked at those Mini-ITX solutions? http://www.mini-box.com/site/index.html
Message edited by WR2 on 06-26-2008 at 09:35:23 PM
Reply to WR2
- 0 +
Might want to read up on the AMD 780g chipset boards with one of their 45W chips. Pretty cheap setup, and with a file server you don't need a ton of processor power.
Reply to tonyn84
- 0 +
Thanks I'll have to look into the 780g setup. Is there a good MoBo with video out on that chipset? Also I thought the AMD processors aren't as efficient as the intel Core 2 Duo processors? I thought there used to be a chart that showed energy efficiency for the processors on Tom's chart section but couldn't find it. Also figure with all the energy efficient computer parts being reviewed lately Tom's would've made a super energy efficient something article...
The mini-box is very interesting not exactly the application I'll be using it for but I'll be looking into that, I may have future use for that site.
I currently have an old PC that I use as a workstation and fileserver. But it's no longer good as a workstation and as a fileserver it simply doesn't have enough HDD space. I intend to donate my old PC to a friend that needs computer parts.
budget isn't that big of an issue, but i figure this wouldn't cost more than $2000 but price isn't an issue at the moment. From the little that I've found online and attempted to piece together on Newegg.com I didn't go beyond $2000.
HDD space is going be around 1TB for the main storage space, and some smaller RAID 1 setup for the system drive.
thanks this has been very helpful thus far... any more info would still help though! =)
darzon
Message edited by nozradd on 06-27-2008 at 03:59:40 AM
Reply to nozradd
There are 481 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
