Tom's Hardware > Forum > Overclocking > CPUs > I7, ex58-ds4 voltage problem, please help
Forum Overclocking : CPUs - I7, ex58-ds4 voltage problem, please help
CPU: i7 920, CO stepping, cooler thermalright ultra 120 EX i7
MB: ex58-ds4
RAM: 6GB corsair 1600 c9d
I'm currently running the CPU @ 3.33MHz (166x20), Vcore 1.248V in CPUZ, eventhough i set 1.3V in BIOS. Its tested stable, 63 degree C load (under P95), also my Ram is running at 1333MHz with 8-8-8-20 timing, command rate 1T, voltage 1.64V
The problem I got is that when I tried to increase CPU speed over 166, I would have to increase voltage so much to be able to boot the system.
At 183MHz (3.66). Vcore: 1.46V to boot to Windows but crashed after 2 sec of Prime 95. I then increase Vcore up to 1.51V and it crashed after 10 min in prime 95, temperature was at 70 degree C at this speed
At 175MHz (3.5). Vcore: 1.41V to stablize system (only 3hrs Prime95 though)
Is there any potention problem with my CPU/MB?, because everyone else seems to be able to get the CPU running at 3.8GHz with Vcore of 1.35 or something.
Whenever I set Vcore in BIOS, the amount shown in CPUZ or speedfan is always .05 lower (eg: 1.3 in BIOS, 1.25 in CPUZ...), is this common ?
I can't seem to get it stable at 3.8GHz, and is it worth it if Vcore would have to be so much (like 1.45V+)?
Is my ram timing good, can I improve anything else at my current speed 3.33GHz?
Sponsored Links
All I know is that there are recommended limits for the Vcore and UnCore. Maybe the resources provided here may help you: Intel Core i7 Overclocking How-to
Reply to Lavarin
- 0 +
I just finished overclocking on a gigabyte extreme, 920...
I woudn't put u'r vcore up to 1.51 again, infact i'd keep it around 1.40 or so...i have the same problem where voltage set in bios appears/is lower on cpu-z. I'm thinking cpu-z is the more accurate reading. Ideally u want to stay under 1.375 volts on vcore, so 1.40 should be max. I'm at 4ghz at 1.38 something volts (in bios) and 1.36 on cpuz (d0 step - if that matters).
u might be getting crashes/errors because your memory or uncore is not set right.
what is u'r uncore speed? should be twice your memory, so at least 2666mhz.
whats QPI/VTT voltage? set it around 1.3 or something.
Maybe put your dram voltage to 1.66 if its not. Gigabyte defaulted to 1.5v volts on my memory (at lower speeds) but the memory behaved erratic at that voltage.
Message edited by dave_74 on 06-30-2009 at 11:29:13 AM
Reply to dave_74
There are 1401 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
