I'm looking to get a new motherboard for my new 4850 (I don't plan on CF) so I was looking at the P45 chipset. I see that for roughly the same amount I can get the following boards (listed from cheapest to most expensive):
Gigabyte GAEP45DS3
Asus P5Q
Asus P5Q Pro
Gigabyte GAEP45TDS3
Gigabyte GAEP45DS3R
Are there any major differences between these boards? (I plan to use ddr2 memory only) Or should I get simply the cheapest of the bunch?
