Tom's Hardware > Forum > Homebuilt Systems > New System Build > Help deciding on parts! please help, specially with mobo
Forum Homebuilt Systems : New System Build - Help deciding on parts! please help, specially with mobo
I'm planning to buy a new PC, can you advice me on this parts?
The website that I'm planning to get is www.auspcmarket.com.au , so if you think another piece is better, please recommend me from this site ;)
CPU
INTEL CORE2 QUAD Q9300
[url]http://www.auspcmarket.com.au/show_product_info.php?input[product_code]=CP-BX80580Q9300&input[category_id]=[/url]
MOTHERBOARD
GIGABYTE GA-X48-DS4
[url]http://www.auspcmarket.com.au/show_product_info.php?input[product_code]=MB-GA-X48-DS4&input[category_id]=[/url]
MEMORY
CORSAIR TWIN2X 4096MB DDR2
[url]http://www.auspcmarket.com.au/show_product_info.php?input[product_code]=AL-T2X4096-64C5&input[category_id]=[/url]
GFX
Sapphire Radeon HD4870 512mb
[url]http://www.auspcmarket.com.au/show_product_info.php?input[product_code]=VI-VGASAP51248K&input[category_id]=[/url]
CASE
NZXT Hush
[url]http://www.auspcmarket.com.au/show_product_info.php?input[product_code]=AIT-CSNZHUBB&input[category_id]=[/url]
PSU
Corsair HX-620 620w
[url]http://www.auspcmarket.com.au/show_product_info.php?input[product_code]=AL-CMPSU-620HX&input[category_id]=[/url]
I will use the system for gaming as well as encoding.
Reasons I chose the Q9300 instead of the Q6600 is I get a $40 discount for that CPU, so the difference is very small.
Reasons I choose the X48 is that I want to buy another 4870 to run them in Crossfire.
What do you guys think? which things from the website I mentioned above you would change, staying at similar cost?
Thanks all!
ps-links seem not to be working, please copy paste ;)
Sponsored Links
I would not choose the Q9300 over the Q6600 especially if you overclock. Go with the Q9450 if you can afford it instead. Q9300 is a poor overclocker due to its low multiplier and it only have 6MB cache (8 on 6600 12 on 9450).
Thank for you going Crossfire instead of SLI :D.
If you want to CF get a 750W+ PSU.
------------------------------ http://www.tomshardware.com/forum/ [...] ate-modode <-- Computer Builds
Success comes from knowing that you did your best to become the best that you are capable of becoming."-John Wooden
Reply to shadowduck
- 0 +
Thank for you going Crossfire instead of SLI :D .
Good advice. Either get q6600 or upgrade to q9450. Skip q9300. 750+ w psu is needed for dual 4870, ideally 850w.
------------------------------ Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Reply to dagger
+1 for skipping the Q9300 since it is handicapped with low l2 cache and multiplier. Would get at least 800W psu for the dual 4870s.
Reply to Shadowthor
- 0 +
Changing the parts to:
CPU
Intel Core2 Quad Q9450
[url]http://www.auspcmarket.com.au/show_product_info.php?input[product_code]=CP-BX80569Q9450&input[category_id]=[/url]
POWER
Antec TPQ-850W
[url]http://www.auspcmarket.com.au/show_product_info.php?input[product_code]=AL-TPQ-850&input[category_id]=[/url]
How does this looks?
The only problem I see in this, is that it's ~au$220 more dollars just for this uprades.
I have never OC and I'm not sure I will.
Are this upgrades worth the difference in money?
Reply to andydev
- 0 +
small bump
Message edited by andydev on 06-27-2008 at 08:20:23 AM
Reply to andydev
Bad situation, because Q9450's the best of the bunch, yet Q6600's a great cost effective alternative, yet there is no good middle ground, the Q9300 is half cache so I say no go.
------------------------------ Intel qx9650 @3.81GHz (10x multi) + EVGA 780i SLI mobo @381MHz FSB
2x EVGA 8800GT 512mb OC'd, OCZ DDR2 1066MHz 4gb
OCZ 850W PSU, Seagate 750GB HDD SATA 32mb cache CM Stacker 830 SE
Sound setup: FireFace 800, JBL 4328 speakers
Reply to resonance451
Antec PSUs are good but sometimes overpriced. How much is that PSU? Is it SLI/Xfire certified?
Reply to shadowduck
- 0 +
The price is OK for me :)
It's XFire certified, which is what I need.
'm thinking of getting this cooler: Thermalright 120 Extreme. Would it fit the NZXT Hush case?
Reply to andydev
- 0 +
http://www.buy.com/prod/corsair-tx [...] 78325.html $99.99 FREE SHIPPING
Corsair TX 750W ATX 12V Power Supply - CMPSU-750TX
------------------------------ "God invented Google so you would stop asking stupid questions."
Reply to Why_Me
There are 485 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 13:08 OvrClkr won the Overclocking badge
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
