Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Help choosing i7 920 CPU/Heatsink
Forum Overclocking : Cooler and Heatsinks - Help choosing i7 920 CPU/Heatsink
I will be building a i7 920 build and need some help on choosing a CPU Heatsink and Fan. Currently, I have the Cooler Master HAF 932 case, Corsair 850TX PSU, and looking into adding a Gigabyte motherboard (UD4P or UD5). 6GB of G.Skill or OCZ RAM, 1 GTX275 (second later on), and 3x WD 640GB Black drives (32MB cache). I would also like to note that noise is not a problem as long as the CPU is an ice cube (minus water-cooling) and I will be using the Tuniq TX2 thermal compound.
Right now I have the Xigmatek Dark Knight cooler in my cart:
XIGMATEK Dark Knight-S1283V 120mm Long Life Bearing CPU Cooler - $39.99
http://www.newegg.com/Product/Prod [...] 6835233029
Is this one of the best cooling options available right now? Or would something else be better?
How about these items? :
Noctua NH-U12P SE1366 120mm SSO CPU Cooler - $74.99
http://www.newegg.com/Product/Prod [...] 6835608007
^^In one of the reviews I think someone said it had less "copper pipes" and therefore would not be able to transfer as much heat. True?
Scythe SCKBT-1000 120mm Sleeve Kabuto 6 Heat Pipes CPU Cooler - $44.99
http://www.newegg.com/Product/Prod [...] 6835185098
^^Read some good things about this company making cool and silent coolers.
The CPU Heatsink and Fan does not have to be purchased from NewEgg either if they do not carry the more effective coolers.
Thanks for the help!!
Sponsored Links
The Scythe CPU fans are very nice, and quiet.
Reply to AKM880
you can go for water cooling in that range and your cpu will be cooler. Check out this link on newegg
http://msi.com/index.php?func=prod [...] =1695#menu
Reply to umeshkumawatsa
I am really really sorry i gave u a wrong link check out the following correct link
http://www.newegg.com/Product/Prod [...] -%20%24100
There are 501 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
