Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Squealing noise, monitor loses signal help
Forum Homebuilt Systems : General Homebuilt - Squealing noise, monitor loses signal help
Hey guys,
I was playing c&c 3 just now and all of a sudden the monitor signal was lost and this electrical squeal started coming from the system, I then had to turn it off by the power switch. I think it could be my sound card as it blue screened when playing jedi knight 2 a while back (it was a reproducable error caused by a sound card driver) and that had similar symptoms.
My rig is x2 6000
ga ma 770 ds3
2 gigs xms 2 800
2 sata harddrives
2 nec ide burners
600 w power supply
Everything has been working fine with it till now. Anyone had similar issues, if it's the sound card I'll just use the onboard I think. Btw it's working ok after as I'm writing this post on the same machine.
Sponsored Links
Also have an 8800gt, would have just edited the message but I can't seem to edit any message here.
Reply to spanner_razor
pull the sound card and try it w/o.
you sure didn't need to post to get that advice
Reply to Groo
There are 1032 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
