Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Please Help! Hard Drive Problem!
Forum Homebuilt Systems : General Homebuilt - Please Help! Hard Drive Problem!
Good evening,
So I'm finishing up my new rig, and I go to install XP. This is a standard vanilla version of XP. No Services packs, nothing.
Anyway, I get to the part of the windows installation where it's a blue screen, and it says to select the partition you want to install windows on.
Well, the only partition listed there is definitely my hard drive, except that it's saying the size is only roughly 131 gigs instead of 250 gigs.
I know that hard drives don't format to their advertised size, but 131 gigs down from 250?
I will also mention that in the bios it says that the drive is 250 gigs. I don't understand why windows installation is saying otherwise.
What gives?
Sponsored Links
There should be an area in the BIOS to select for "Large Disks" (SP2 does not have this issue) you could also try slipstreaming SP2 into the install. Don't remember how, but someone else on this site may. the HDD could just need re-formatted as well (someone may have formatted it previously) delete all partitions (in the area that XP asks to select a partition) and create a new partition, and format in NTFS (FAT/FAT32 has issues with disk size).
in other words delete all partitions, create a new one, then format in NTFS.
Reply to IH8U
before SP1 ~ windows can only recognize that amount. there's nothing wrong but unless you want to slip stream a service pack, just install then install the service packs and adjust the partitions then.
use the search function for a more detailed explanation. This has been answered many times (and I'm too lazy to look it up again)
Reply to bc4
Agreed. Why don't you just have 2 partitions anyway? That gives you a back up partition to hold your data in case you need a clean install. Also partition imaging (backup) software needs a separate partition to back up to.
Or you can slipstream SP2 on to an install CD, as said.
Message edited by Zorg on 06-27-2008 at 06:40:58 AM
Reply to Zorg
There are 708 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
