Tom's Hardware > Forum > CPU & Components > CPUs > Will dual core help on remote connection over pentium 4?
Forum CPU & Components : CPUs - Will dual core help on remote connection over pentium 4?
Hi,
I currently have Pentium 4 (400) and my employer suggested that upgrading to dual core may improve productivity. I know that dual core is faster/more efficient overall, but will it really make much of a difference when I connect to my employer via a remote desktop connection? I primarily use my computer for internet and word processing applications. (no games)
I always assumed that as long as my internet connection was strong and fast that the rest depended on their system. Is this correct?
Thanks!
Sponsored Links
No, LAN speed determines the speed of the remote connection. With a relatively new CPU the bottleneck, however minor it would be, would be in the connection. For basic tasks such as typing in Office or surfing on the internet, not much benefit would come from dual-core unless you are buying a more energy efficient processor to lower overhead costs such as the AMD 4850e or Intel E7200.
Reply to amdfangirl
it would make moving around the desktop "snappier", but would achieve little else
Reply to spuddyt
Thank you! I try and tell them that when their server is slow, mine internet fine, but they dont listen.
Reply to 777chris
Do what your boss says, or you might get fired.
Dont argue with the guy that signs your check.
If its part of the job they should have to provide what you need.
Reply to roadrunner197069
Reply to 777chris
It wasn't my boss, but a supervisor who isnt an IT person who thought it "might" be a problem.
I'm just trying to figure out if I really need to spend my own $$ on a new computer that may or may not solve a problem. If it will solve a problem, then I'm all for it.
Reply to 777chris
Yes, a server internet upload upgrade would be more beneficial. Your computer is fine the way it is =)
Reply to amdfangirl
There are 1117 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
