Will this PSU hold with 4870x2?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Will this PSU hold with 4870x2?
So, I am planing on buying a new video-card, the 4870x2!
My system specs are
MOBO: xFx 680i SLI
CPU: Core 2 Q6600
RAM: Corsair XMS2(DHX) PC-6400 4 x 1Gb modules
HDD: Samsung Spinpoint T166 320Gb
Video-Card: [url]Powercolor Ati X1950Pro 512Mb
PSU: CoolerMaster eXtreme Power Duo 600Whttp://www.sysopt.com/features/cas [...] hp/3622766
Now the reason for me having an Ati card on a nVidia motherboard is because I got the video card and the PSU first.
Then later on I bought new ram, cpu and the mobo with a plan buying an nVidia video-card when i felt that my current card was outdated.
But see now the hing is since Ati launched its 48xx series i think i am gonna stick with Ati.
So that's why i am wondering if my PSU would hold if a got an 4870x2?
If not then im was thinking about getting a Corsair 750W power supply.
I was thinking about getting Asus Maximus Formula II motherboard, but i headr that Intel is coming out with a Nehalem CPU around Christmas. So it would be stupid to buy a new mobo that does snot support the new cpu series...
Any ways, will my PSU hold?
Thanks
Sponsored Links
a review site posted the power usage of two 4870's in normal crossfire (cant remember the sites name), it showed that the cards used around 480w under full load. the 4870X2 will probably consume alittle less given that its on one board. Probably around 450w under load.
If your PSU can produce that then your fine. Coolermaster is a good brand in my book, but i do think you may need alittle more. maybe a CM Realpower 650W just in case.
Reply to b_3d
- 0 +
Ok, but then ill just go for the Corsair 750W cause i got a good deal on it.
But, the 4870x2 should work fine with 680i board right?
Message edited by RME on 08-17-2008 at 02:16:48 PM
Reply to RME
- 0 +
i think it will. the Crossfire configuration is on the card itself and not on the motherboard(like normal croofire). if you Want to Xfire (two 4870x2 in crossfire) then you will need either an AMD Chipset or one of Intels inhouse boards which support ATI
Reply to b_3d
- 0 +
Ok thanks!
Reply to RME
- 0 +
Any other comments or suggestions are still welcome!
Reply to RME
- 0 +
no its fine it should work great.
------------------------------ intel core 2 quad q6600 @3.2ghz msi p6n diamond (X-FI Extreme sound) 6gig of OCZ+CoRSAIR oc 900mhz Nvidia gtx 260 sli @ 730/1465/1250
Lite-On Blue-ray Western Digital 7200rpm 500gb Antec 500 Earthwatt Window vista 64-bit
Reply to invisik
- 0 +
"It should"
XD
I, NEED it to work!
Reply to RME
As far as the 680i board, its not a problem, itll work flawlessly. The chipset is nVidia, but the x2 is internal CF, so it actually works within itself, and not across the mobo, so it doesnt require a ATI/AMD/Intel chipset. If, however youd ever want to use 2 cards, then youre stuck with nVidia cards. If youve got the 750 corsair, that also should work fine, and youll have 1 helluva setup
------------------------------ I went drifting, thru the capitols of tin, where men cant walk and cant freely talk, and sons turn their fathers in
Reply to jaydeejohn
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Will this PSU hold with 4870x2?
There are 1418 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
