Tom's Hardware > Forum > Homebuilt Systems > New System Build > New system build... need some input!
So I'm moving out and decided to donate my old comp to a friend so he can actually play games with me online. Now I find myself without a computer and had to borrow my brothers... Not fun.
Luckily, I can build a new system for myself and put it in the business as an expense so my budget is basically whatever I "need/want!"
So... here's a little background info...
I play a lot of different games (Crysis, Bioshock, TF2, COD4, etc) and currently play on a 24" 1920x1200 resolution monitor, with a second output going to a large LCD 1920 x 1080 tv.
I've built about 10 systems over the past few years for myeslf and friends am experienced with overclocking, watercooling, and even a few case mods.
Now my problem is, there are way too many options out there!
What have a decided for sure?
Case:
Either a Coolermaster Cosmos S
http://www.newegg.com/Product/Prod [...] 6811119150
Or Coolermaster Stacker 830
http://www.newegg.com/Product/Prod [...] 6811119122
I want DDR3 memory. (Is the DDR3 2000 kit worth it?)
Either 4GB of
http://www.newegg.com/Product/Prod [...] 6820145190
Or 8GB of
http://www.newegg.com/Product/Prod [...] 6820227297
Power Supply
http://www.newegg.com/Product/Prod [...] 6817814011
Beyond that? It's all up in the air...
Do I want to get a QX9650? or just overclock a Q9450?
Which motherboard to get? Obviously depends on the graphics cards I use!
Graphics cards? If I'm going to get an ATI I want the 4870x2 that's not out yet, so in the meantime should I just buy a 9800Gx2? I can give it to my brother after to use. Or maybe I can buy 2x 4850's and give those to him after (his mobo is a crossfire board)? REALLY not sure what to do! I've even considered getting two GTX280's. This is one area I need some advice!
Hard drives? Two velociraptors in raid 0? or Two 1 TB Samsung F1 drives?
Once I decide on components I can put all this on order! I'll order the case ahead of time because my friend is going to be painting it for me and I may get the inside powder coated.
I'm also doing full water cooling with an air conditioned radiator that I can stick outside in the winter!
Any help will be appreciated!
Thanks
Sponsored Links
for the graphics card... get a 4870 ... then when the 4870 x2 comes out crossfire them
the processor... just OC a q9450
ram I know this isn't newegg... but TG has better prices on this ram
http://www.tigerdirect.com/applica [...] CatId=3485
its much cheaper and will still work
the MOBO I'd go with a good X48 right now... can't suggest specific ones b/c I haven't done research into it sorry =(
HDD... since you said money isn't a factor (at least not major) i'd raid 0 the velociraptors
thats what I personally would do... don't know about anyone else though... threads like this always have different builds =D
Reply to thogrom
I have the CM Stacker 830 case and it's very good but the side panels are a pain to put back on for some reason.
If you're going to use 2 monitors I would definitely get Sli or Crossfire graphics cards. Get the 2 of the 4870s and Crossfire them or the GTX260/280 and SLi them.
Get 8GB of RAM if you're using a 64bit OS, I have 4GB of RAM and Vista 64bit uses 30-45% of RAM when it's idle.
For the processor, save some money and get the Q9450.
For the HDD I would get 2 velociraptors because 2TB of HD space just seems way overkill to me.
The PSU might be a bit overkill, maybe get like a 1000w(it might not be overkill, that's just what I think)
Reply to efx92
lol business expense... lucky son of a b!tch. that's all i got to say about that :kaola:
Reply to arson94
Case - I'm not sure, but the Cosmos 1000 was a good case so I'm guessing the S only improved on it.
PSU - PC Power and Cooling 750w. 1300w is just overkill.
CPU - Q9540
GPU(s) - Either the two 4850s or two 4770s. SLI DOES NOT support multiple monitors as of yet, where as Crossfire does.
Mobo - Gigabyte GA-X48-DQ6 or if that is too expensive the GA-X48-DS4
HD - I'd go in the middle :p two Western Digital SE16 Caviar 640GBs in Raid 0. They are fast and quite because the only have 2 platters.
Reply to tharros
Thanks for the replies so far, seems most people are going to have a variation of the same basic build in mind. :)
So, you seem to mostly agree that the ATI 4800 serires is better value, and while I do agree, I have to consider the fact that IF the 4870x2's come out and they are kick ass then I will be getting two of them and whatever I have in my computer atm will be a gift for my brother. So should I still get two 4870's?
Nobody suggests the QX9650 processor, and personally I think I agree, but what's going to be the difference in performance on a moderate but stable water cooled overclock? Also is the unlocked multiplier worth it for getting the ratios correct?
I'm getting the 1300w PSU no doubt. I always make it a priority in my systems and because of that I've NEVER been in a situation where I had to buy a new power suppy because I upgrade graphics cards. Actually I've even kept PSU's from one build to the next.
Finally the HDD's if I get the two velociraptors I'll be adding a 1TB hard drive as backup either way. I do HD video editing and will probably keep adding hard drives to help support my media server :)
Thanks for the input folks!
Reply to cokenbeer
There are 1198 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
