Hey,
Ive had a look around for people posting the same problem, but cant seem to find anything so...
When I first try and turn on my computer sometimes my monitor will not pick up a signal. Repeatedly turning both the monitor and computer on and off will eventually get it to work. Sometimes it will work the first time I try, sometimes the second, but sometimes it can take 10 or even 20 attempts before it finally works which, believe me, started to get annoying after the first week or so.
The problem only appears at startup. Restarting the PC from windows or letting it go to and return from standby never brings up the issue - once it has a signal it is absolutely fine and there dont appear to be any other problems once the computer is on (RAM, VGA card, CPU all seem to display and run properly).
There is one other detail though. One of the case fans wont always start. It just sits there... until you give it a little nudge and then it runs fine. The other two dont have this problem, its just the one that doesnt like to start by itself.
Ive had the computer (self-built so no warranty) for two years and the problem cropped up about a month ago and has kept happening since. Im finally getting sick of it now. It didnt happen after any driver updates so that cant be the problem either, which leads me to believe its hardware over software.
Ive tried another monitor and another cable so neither of these are to blame. Unfortunately I dont have any other spare components to try to narrow down the problem to a specific piece of hardware.
Anybody have any ideas?
Thanks.
Specs:
24" DMQ Monitor
Gigabyte GA-965P-DS3
C2D E6300
2GB RAM
Connect3D X1800XT
Hiper Type M 530W
Thanks.
Specs:
24" DMQ Monitor
C2D E6300
2GB RAM
Connect3D X1800XT
Hiper Type M 530W
